Old 02-03-2007, 10:58 PM   #15
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
It is mounted about 5 feet from the floor. High is good for smoke because it rises. CO is almost the same weight at air so location can vary for that function. Our trailer has a mid double bed and the unit is mounted on the bed side of the wall just past the kitchen area.
Richard
Old 02-18-2007, 03:18 PM   #16
sequoiacoast's Avatar
1968 24' Tradewind
Eureka , California
I bought the LP & CO detector from camping world and am now ready to hardwire. I had asked the RV place to splice in wiring for this, but ended up with only one red wire. I have white 18 awg 600v type TFFN or MTW wire around the house... would this work for the neg. splice?
Also, can I splice in the LP detector to the 12v that feeds the furnace? This way I can mount it near the floor in the galley area.
Thanks, as always!!!
sequoiacoast is offline   Reply With Quote
Old 02-18-2007, 05:39 PM   #17
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Combination LP and CO? That is a bad design.
LP Sinks, CO rises. LP detector needs to be mounted low and CO needs to be mounted high. Mount it to correctly detect one it will not do a proper job of the other. One or the other will kill you before you know it.
My LP detector is mounted by the Refer and stove about 6" from the floor.
My CO detector is mounted in the Bedroom about 4" from the ceiling.
Michelle TAC MT-0
Sarah, Snowball
Old 02-18-2007, 07:01 PM   #18
1968 24' Tradewind
Eureka , California
My detectors are not a combo. I have one of each and plan to mount them as cats has indicated. I am wondering if the splicing and wire I have will be ok.
Thanks!
Old 02-20-2007, 07:55 AM   #19
Keymar , Maryland
The way it was posted I thought it was a combo unit.
Michelle TAC MT-0
Sarah, Snowball
Old 02-20-2007, 08:04 AM   #20
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Originally Posted by boatdoc
Hi Silver Threads; It is best to have a dual function. Best we found is Safe-T-Alert from Marine Technologies Inc. This unit, in addition to monitoring LPG and Carbon monoxide will also detect Methane gases. It can operate solenoid type shut of valve for LPG and the generator shut down feature will shut down your generator should exhaust gases enter your trailer. The last feature can be life saver when operating the generator outside while windows are open. Price $ 115.95 Good luck, "Boatdoc"
I have this unit on my boat and it works great and reliable. Just went thru a hard beaching on a parking lot due to Katrina, I tested it last week and it works perfect.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 02-20-2007, 08:10 AM   #21
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Hello everyone- Michelle is absolutly correct on this. I am of the old school and believe that you should have a sepperate unit for everything! The gas detector comes all by itself and need to be located 2" off the floor hard wired. Yes, you can purchase combination units for smoke and Co2 but I feel much safer with one unit for each. In case of failure of one you always have the other to back you up. In an enclosed TT the more precautions the better. Quick question for everone; how many of you have added additional extinguishers to your Airstreams. The one little one by your door is required by law but I feel better with an additional unit by the stove and by our bed. No I am not parinoid, just careful.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 02-20-2007, 11:09 AM   #22
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
An extinguisher upgrade is a great idea. But, IMO the door location is the best location for the primary one. Other locations are not necessarily bad.
The reasoning for the next-to-the-door location is that you should be exiting the trailer FIRST, then you can then attack the fire with the extinguisher IF it is safe to do so with a small fire. First get out.
Travel trailers, like mobile homes, burn extremely fast due to the materiels with which they are made. They won't give you much time. This is why detectors are particularly critical for RVs.
Dave
Fyrzowt is offline   Reply With Quote
Old 02-21-2007, 03:23 PM   #23
Jacob D.'s Avatar
1964 26' Overlander
Alameda , California
Originally Posted by thecatsandi
LP Sinks, CO rises.
LP certainly does sink, but from what I can discern from reputable sources like the CPSC, CO mixes with air in the room and so a CO detector can be mounted at any height. What's more important is that it can be heard, is close to the sleeping area, and can't be blocked by furniture or drapes. So a combination LP/CO detector mounted at floor level should work well.
This is from the CPSC site:
CO alarms should be installed according to the manufacturer's instructions. CPSC recommends that one CO alarm be installed in the hallway outside the bedrooms in each separate sleeping area of the home. CO alarms may be installed into a plug-in receptacle or high on the wall because CO from any source will be well-mixed with the air in the house. Make sure furniture or draperies cannot cover up the alarm.
The one I have is 12V hard-wired, which eliminates the possibility of letting the internal battery go dead - which is more of a risk in an RV where you might not be in there for months at a time to hear the low-battery beeps. Of course, you need 12V power for it to work, but you're more likely to notice a lack of 12V power in the trailer than a dead 9V battery in the detector.
Jacob D. is offline   Reply With Quote
Old 02-21-2007, 03:59 PM   #24
Silver Threads's Avatar
2000 25' Excella
Kingston , Tennessee
We bought one at Lowes that detects "Propane and Carbon Monoxide". It plugs in and comes with a battery. It also detects several other gases. Was 60.00. Hope I did the right thing.
John & Tammy Adams
Silver Threads Custom RV Curtains
2000 Airstream Excella | AIR 15902
https://www.etsy.com/your/listings
Silver Threads is offline   Reply With Quote
Old 02-21-2007, 06:11 PM   #25
Keymar , Maryland
is it a truly combination unit? It should be mounted low. Although I would look for seperate units.
While CO does mix with the air. If the air is not moving it will rise. Placing the dectector high will cover both situations.
Michelle TAC MT-0
Sarah, Snowball
Old 02-21-2007, 06:53 PM   #26
2000 25' Excella
Since the Airstreams are not as big as a house per say, dont you think it would detect either pretty quickly?
John & Tammy Adams
Old 02-22-2007, 06:12 PM   #27
1972 25' Tradewind
Madison , Wisconsin
Detectors
A lot of good info in this thread, made me think about a mod to my set up.
The detectors will be sensitive to the relative density of the gas (what % of whatever you are looking for). Being a small space it means less CO or LP will come up to the detectable level mor quickly.
John HD had the right idea for placement. If one is concerned about a battery discharge to hard wired detectors, an easily visible switch or two could turn the detectors off when appropriate. Visibility would be good so as to check the detectors switch position. A power light led side lead or switch would let you know you when you have power on the line. Just make sure you use a DC switch especialy if it is illuminated. It may not be critical because of the low draw of the detectors, but why mess around, use good stuff.
Breathe well!
Smokin Camel is offline   Reply With Quote
Old 06-16-2007, 10:15 PM   #28
danesh's Avatar
Original Detector
Hello Everyone:
We have a 84 AS and it has an original air detector (detects dangerous gases) hung on the wall close to fridge. It has a off, normal, and high sensitivity switch. Does any one know if this unit is still ok to use? It is more than 20 years old. It does come on when there is gas smell (I have tested it with the gas lighter).
Cheers
85 sovereign
danesh is offline   Reply With Quote
Low Tire Detector Pahaska Tires 31 12-19-2007 04:58 PM
LP Gas/Carbon Monoxide Detectors Joseph O. Smith LP Gas, Piping, Tanks & Regulators 28 11-02-2002 01:22 PM
Smoke Detector ViewRVs Airstream Motorhome Forums 7 09-02-2002 07:57 PM
Flat tire detector Pahaska Tires 6 08-08-2002 06:38 PM
Gas Detector winner Airstream Motorhome Forums 2 07-02-2002 03:59 PM
