04-22-2015, 09:53 PM
2015 30' FB FC Bunk
Ayer
, Massachusetts
Can't fill Fresh water tank, leaving in the morning
I am loosing all of my freshwater out of this tube, brand new trailer never filled before. Any help is appreciated. Leaving in the morning for 1100 miles. Thanks
04-22-2015, 09:55 PM
2015 30' FB FC Bunk
Ayer
, Massachusetts
Trying to upload photo
04-22-2015, 10:16 PM
1999 34' Excella
Hillsboro
Ted, if the valve is your freshwater tank drain, turn the handle 180 degrees. If the top lever is missing, carefully turn the lower section using pliers,... don't force!!
Peace and Blessings..
Channing
WBCCI# 30676
04-22-2015, 10:27 PM
2015 30' FB FC Bunk
Ayer
, Massachusetts
Trying to upload photo, the petcok looks completely missing...
04-22-2015, 10:31 PM
2009 30' Classic
Melbourne, FL
, Searsport, ME
You're right. It's been broken off. Forget filling the FW tank until it's fixed. Should be an easy fix at any RV repair facility.
P.S. Actually after closer observation, it may just have been left open. Try closing it by turning it clockwise.
04-22-2015, 10:41 PM
1999 34' Excella
Hillsboro
The handle is small and on top
Channing
WBCCI# 30676
1999 34' Excella
Hillsboro
If broken, grab the nozzle and turn counter. Clockwise. See if water stops. It does on mine.
Channing
WBCCI# 30676
04-22-2015, 10:43 PM
2015 30' FB FC Bunk
Ayer
, Massachusetts
Does that whole fitting turn? It seems pretty solid, nothing is broken, none of the parts have a break.
04-22-2015, 10:58 PM
Spokane
No, just the little handle part on the very top. Mine is stiff but it turns. You might need a pair of pliers.
04-23-2015, 04:14 AM
2012 27' Flying Cloud
W
, New England
Ted. I can't see high enough from that picture but there should be a white plastic wing right on that tube just higher up than where your photo shows the tube. It's probably laying flat against the tank. You want to twist it so its pointing out toward your face as you're looking at it from in between the tires. If it is broken or missing you can try carefully closing the valve by grabbing the lowest portion of that white tube with pliers an twisting it closed. Good luck!!
04-23-2015, 05:31 AM
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington
, Ontario
When that happened to my valve, I found a bolt that I was able to screw into the hole and plug it up. That road fix lasted 10 years. I found the bolt laying on the side of the road about 10 ft from where I was stopped. Jim
04-23-2015, 05:44 AM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
As mention above, the petcock looks intact from your pic.
The item in the pic is the drain for the fresh water tank. It is used to winterize the trailer, or flush the freshwater tank.
There should be a small "handle", like half a wing nut, on the top of the white plastic valve.
These valves can be stiff, but you need to rotate it 180 degrees to close it. Think of the valve in a cucumber water dispenser in a fancy place somewhere. It rotates in the horizontal plane.
Sometimes a little extra grip from a pair of pliers helps, but be careful.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
04-23-2015, 06:28 AM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
Did you get this fixed? In looking at the picture the valve is open, the valve is often as mentioned very hard to turn, I often use a pair of needle nosed vice grips to grab the little bugger and get it moving and then grab it with my fingers to turn it closed.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
04-23-2015, 07:28 AM
Biloxi
, Mississippi
DIY Special Tool created to make turning the valve easier. It is not very pretty but does the job.
MICHAEL
04-23-2015, 09:39 AM
Ready-to-Travel
Walkerton
, Virginia
I found it pretty quick and effective to carve down a wine cork with my pocket knife.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
04-23-2015, 10:10 AM
2015 30' FB FC Bunk
Ayer
, Massachusetts
Thanks everyone. The valve was open, I didn' t see it last night, it is up high as you describe. My kids thank you as now there is no need to use public restrooms.
04-23-2015, 12:59 PM
1999 34' Excella
Hillsboro
Hanks for closing the loop!!!! Have a great time!
Channing
WBCCI# 30676
04-23-2015, 01:33 PM
2019 27' International
2014 25' International
Boulder City
, Nevada
Stick a cork into it and "duct tape" to secure it
Anyone having a petcock actually broken off. This is a great repair on the road for minimal cost.
We had our drain petcock broken off flush just after purchasing the Airstream. A small cork from Ace Hardware fit, bought several extras, used a picture frame wire that we had a spool with us at the time, cut off a section to secure the cork.
The cork was secured by this wire by wrapping the wire onto the two philips head screws. Back one out just enough to wrap the end of the wire, and tighten. Run the other end across the top of the cork, keep as tight as you can, wrap the end around the second philips screw and tighten. Worked for two years and you unscrew one screw, back off the screw enough to pull out the cork to drain.
This area has no protection, at least in 2006, to shield this from road gravel hitting it and breaking it off. Jackson Center, OH added extra sheet metal to protect all sides and we never had another issue.
So supplies: flexible picture hanging wire, small cork, philips screw driver.
I estimated the diameter of the cork that would fit by taking three or four sizes. Ace Hardware in Nevada, when we stopped to find a fix, let me take out which ever size corks they had to offer. One fit. Bought extras which I never needed, but just in case. Maybe 15 cents a cork. Worked perfectly.
Human Bean
04-23-2015, 06:15 PM
1987 Avion 34W owner
Good Ol'
, USA
Good! Have a great trip!
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
