Old 03-25-2014, 07:05 PM   #1
1968 28' Ambassador
Ojai , California
Can old LP tank valves be upgraded to OPD valves?
I was told my propane tanks had the older, illegal valves and that I would need to get new tanks with OPD valves.
Is it possible to simply take off the old valves and install new OPD valves?
Thanks! Jim
jimblacker is offline   Reply With Quote
Old 03-25-2014, 07:06 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Jim,
Yes I had new valves installed on the original aluminum tanks on my 1979 Safari.
Bill
Thanks! Jim
Just my personal opinion
Old 03-25-2014, 07:58 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Yes you can. Bring them to a propane dealer. They can re-certify your tanks and install OPD valves. We had that done to 30 LB aluminum tanks.
Chris
Old 03-25-2014, 08:31 PM   #4
1974 Argosy 20
Kooskia , Idaho
Yes, valves can be replaced by a propane dealer at their shop, and the tanks re certified at the same time. Cost will probably be in the $40 each range. Call first to be sure that the shop does that work. I have never had a problem finding someone to do it, but in other posts on the forum I have seen some people having a hard time finding a dealer who will change the valves.
BTW, it is not a do it yourself job. The exact right valve for the tank size must be used, and the equipment to hold the tank and unscrew the valve is not all that easy to come by. It is worth the professional's time. And again, the re certification can be done then too.
Old 03-25-2014, 10:37 PM   #5
mefly2's Avatar
2015 25' FB Eddie Bauer
Yes; around here they charge $10 for recertification of the tank and the cost of the new valve. Just had one done last summer ... a left over from 1970 !
Old 03-25-2014, 11:48 PM   #6
1968 28' Ambassador
Ojai , California
Excellent! Thanks so much for all your replies on this; very helpful!
Old 03-26-2014, 05:10 AM   #7
2000 30' Excella
Toledo , Ohio
If you have aluminum tanks don't let them get replaced with steal ones . Like all the above have said have the opd valves installed , by a propane dealer .
woodfox45 is offline   Reply With Quote
Old 03-26-2014, 05:56 AM   #8
Huh?
Ultradog's Avatar
1975 27' Overlander
Twin Cities , Minnesota
Images: 8
I also had my valves replaced. I have two 30 lb aluminum tanks.
At first I thought I would just buy the valves and switch them myself.
The guy who sold me the valves said it was hard to get them out without the special wrench they use.
I tried it and found it was Much more difficult to remove the old valves than I expected without the tool.
I brought them back and he teased me a little but did it for me.
Ultradog is offline   Reply With Quote
Old 03-26-2014, 06:07 AM   #9
Wise Elder
Jammer's Avatar
2010 30' Classic
I've done it. You can order the correct valves, and purchase the wrench.
Whether it is worth it or not depends on your situation.
Specifications for new OPD valves Phrunes LP Gas, Piping, Tanks & Regulators 16 03-12-2013 06:56 AM
OPD valves for 40 pound aluminum bottle phred LP Gas, Piping, Tanks & Regulators 7 05-30-2009 11:56 AM
OPD valves with wire to propane gauge eubank LP Gas, Piping, Tanks & Regulators 2 09-29-2008 02:59 PM
OPD valves... FAILURE!! Silver Bullet LP Gas, Piping, Tanks & Regulators 10 11-28-2003 08:07 AM
OPD valves, Sight Gauges & Remote Senders femuse LP Gas, Piping, Tanks & Regulators 1 04-29-2003 07:41 PM
