Old 08-19-2014, 02:26 PM   #1
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Can I Drill and Screw Here?
I'm replacing the round 4" sewer hose holders with one made from a square 5" PVC fence post. I'd like to mount it up against the front wall of the grey tank. The pan under the tank and the tank are held in place with a galvanized bar running from right to left and galvanized straps running front to rear. The bolts/lag screws holding the straps also go through holes in the bar, using only every other hole. I presume they go into a frame cross member.
Is there any reason why I couldn'tt use two of the unused holes, drilling into the crossmember, to hold my new hose caddy?
I would be using much smaller hardware, probably #12 or 1/4".
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 08-19-2014, 03:41 PM   #2
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
I drilled and tapped a frame cross member at three points to install my sewer hose holding tube, and can't think of why you couldn't as well.
robert claus is offline   Reply With Quote
Old 08-19-2014, 03:46 PM   #3
dznf0g's Avatar
Oswego , Illinois
Me too. I added two tubes
-Rich-
Old 08-19-2014, 04:19 PM   #4
Thanks guys. I couldn't believe how the existing tubes were installed. One side of the legs of one tube was screwed into a frame member. The other side of that tube's mounts and all four screws of the other tubes mounts were mounted to the belly pan only. Three of the other 6 screws had front or rear mounted backing plates but were still free to flap around with the belly pan.
Al
S/OS #004
Old 08-19-2014, 04:36 PM   #5
dznf0g's Avatar
Oswego , Illinois
Yup, when I added mine, I made a an aluminum plate of thicker skin material, about 3" X 3" and put in place with 4 olympic rivets (to displace the weight over a larger area) and then used expansion nuts to attach the tube foot to the plate/belly skin. One of my tubes contains a cylindrical water softener and a PVC stand. Total weight....22#s. Has held fast for almost 10,000 miles now with no visible degradation of material.
I did also add two PVC pipe hangers on that one as well, screwed to the cross member.
-Rich-
Old 08-19-2014, 04:48 PM   #6
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Best to include pictures with the questions that way we are on the same sheet of music.
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Solar to drill or not to drill-HELP Orson Electrical - Systems, Generators, Batteries & Solar 2 08-24-2012 08:03 AM
Where can I screw (things) up? johnfreeman6 Member Introductions 8 06-26-2011 07:49 PM
Can't stomach screw holes in new Airstream interior... dekew Upholstery, Blinds, Walls & Interior Finishes 24 01-07-2011 09:34 AM
banana wrap holds water - can I drill drain holes? ryan3326 Belly Pans & Banana Wraps 10 09-27-2010 05:36 PM
Drill Baby, Drill! Mount external antenna TropicGuy Computers, Internet & Satellite 5 04-17-2010 03:02 PM
