Old 07-20-2011, 12:40 PM   #1
Ottawa , ON
Can I change my own LP gas regulator?
Or should I have it done by an RV tech?
Guy at the parts store (I know, not the best source for quality information) says that you just unscrew the old one and screw in the new one.
Nothing on an AS is ever that easy, or is it?
Old 07-20-2011, 12:46 PM   #2
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Short answer: Yes. It's a pretty easy job. Get some pipe tape.
Lynn
WBCCI 21043
Old 07-20-2011, 12:51 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
It's not difficult if you've done much plumbing.
You do need to use either a good quality paste thread compound like Rectorseal #5 or a tape dope that is rated specifically for propane. The propane gas causes the plastic to deteriorate in the plain white tape dope that is sold for water piping.
Check for leaks with bubble solution when you're done. The stuff in the toy aisle is cheaper than the stuff in the plumbing dept. and works the same.
In general you should probably replace the pigtails at the same time since the rubber hoses deteriorate. If there is a rubber hose from the regulator to the trailer piping you might want to replace that too.
Old 07-20-2011, 01:01 PM   #4
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
Go for it, if I can do it,its got to be easy. Definitely replace the pigtails, and like jammer said from the regulator to trailer. The latter can be a little harder to find, Mr. Heater has a big selection of hoses, so look there to find the length which is appropriate.
kevinb is offline   Reply With Quote
Old 07-20-2011, 01:03 PM   #5
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
Tried to include a pic
Old 07-20-2011, 01:12 PM   #6
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I think that you could handle the job quite easily. SuEllyn recently replaced both the flex lines from the tanks to the regulator without any problems. She used a thread sealant from a tube made to seal gas lines.
Brian
SuEllyn & Brian McCabe
Old 07-20-2011, 01:19 PM   #7
Ottawa , ON
Wow, thanks for the votes, you all agree! It's anonymous! Erm, no, unanimous, that is.
Off I go to get one.
Old 07-20-2011, 01:44 PM   #8
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
"And I am unanimous in that !" to quote Mrs Slocombe if you ever
watched "Are You Being Served?"!
Brian.
PS as others have said, not hard to do at all, just be sure and leak test. I recently had to replace the main propane line under the tongue of our trailer, I found it was squished almost completely flat. It was still working, and probably was like that when we bought the trailer - I only noticed it when I was installing a Hensley hitch. Looked like someone put a jack under it.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 07-21-2011, 10:28 AM   #9
blickcd's Avatar
Milford , Ohio
If you are replacing the hoses, you might go for some extra long ones. Picture an overturned 5 gallon bucket with a bathroom scale on top right by the trailer tongue. Get hoses long enough so the tank can be weighed without disconnecting them.
blickcd is offline   Reply With Quote
Old 07-21-2011, 10:43 AM   #10
azfiredog300's Avatar
Surprise , Arizona
This is how I did it.
http://www.airforums.com/forums/f287...ego-40056.html
Jerry C.
"Travelstar Galactica"
WBCCI #13317
AIR #25664
Member of the Four Corners Unit
The only true failure is the failure to try.
azfiredog300 is offline   Reply With Quote
Old 07-21-2011, 10:46 AM   #11
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
It's simple. I've changed them on both trailers. The most recent one came from PPL, see LP Gas Automatic Changeover Valves on Sale - PPL Motor Homes.
They also list a remote changeover indicator just below the regulator. I installed one of them at the same time and it works great. Here's a link to details at Tweety's (Marshall Brass Remote Changeover Indicator). PPL doesn't have a link to that product. I've never dealt with Tweety's, but have heard good things here on the forums. I have had great experiences with PPL. Installation is simple, you simply remove the cap on the top of the changeover regulator, the one that clearly says "Do Not Remove", and snap on the sender portion. Route the wires inside and mount the box with the LED and you're done. When the units switches to the backup tank and the visual indicator on top of the regulator changes from green to red, the LED on the box inside starts to flash.
My bottles don't have senders for the level indicators in the control panel, so those do me no good at all. Plus, I would have to go check them. This system works automatically.
Vaughan
Old 07-21-2011, 02:12 PM   #12
Ottawa , ON
Hey, thanks again you guys!
I like the idea of the indicator for the tank switchover, Vern. Where did you put the indicator?
Brian,
Yes, I think I've watched most of the British TV series available here. Netflix is great for that, up to episode 65 of All Creatures Great and Small right now!
Old 07-21-2011, 02:19 PM   #13
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Teflon Pipe Dope And Windex
Aage,
Is everybody else has stated, it's a pretty simple job. Just get some teflon pipe dope (mentioned in another post). Once the job is complete I would run all the LP appliances for a little then turn them all off and leave the LP tanks open. Then take Windex or a soapy water solution and spray it on any fittings you may have put a wrench to. If there is a leak you'll see bubbles. Tighten as necessary and repeat the bubble test.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 07-21-2011, 02:23 PM   #14
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Southern , Wisconsin
Yes...you most definately can! Use the appropriate thread sealing tape or compound and check for leaks! These are only Airstreams...not rocket ships!
All that is gold does not always glitter...those who wander not always are lost....
mnmhays is offline   Reply With Quote
Cooling problem on gas Pahaska Refrigerators 38 08-22-2011 05:18 PM
Gas on, gas off? heavyjumbo LP Gas, Piping, Tanks & Regulators 28 07-23-2011 07:59 AM
Got gas? ROBERTSUNRUS Off Topic Forum 13 06-25-2011 12:14 AM
LP Gas regulator question tvadman1963 LP Gas, Piping, Tanks & Regulators 3 03-10-2011 04:12 PM
