Old 07-07-2007, 11:05 AM   #1
Lafayette , Rocky Mnt. Region
Can a propane generator freeze the regulator?
I am considering getting either the Honda 2000 or the Yamaha 2400 generator and buying a conversion kit to allow it to run on propane. I would also like to connect it into the trailer's propane system. A service manager at an RV dealership recommended against using propane generators because they can pull too much propane through the trailer's regulator causing it to freeze. Has anyone experienced this before? I really like the idea of propane because I pull with an SUV and don't want to carry gas inside the vehicle.
richschafer is offline   Reply With Quote
Old 07-07-2007, 11:12 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It is possible, although I haven't seen it with a generator. I HAVE seen it on some trucks I used to service, mainly in wintertime. If it turns out to be a problem, a regulator is only a few bucks, and you can leave it hooked to the generator when traveling.
Old 07-07-2007, 11:25 AM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I don't really know if what you were told about the propane freezing is true or not, but it shouldn't really matter. I would simply use a separate LP supply hose for the generator and hook it directly to one on the Airstream's tanks. This way the LP supply for the generator would not even being going through the Airstream's regulator.
SuEllyn & Brian McCabe
Old 07-07-2007, 01:13 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you look at this site you will see a second regulator and the adapter needed to hook it up.
Page 3
Depending on the manufactures recomended pressure you can set the second regulator as needed. Just make sure the full flow rate of the regulator is enough for the generator.
If you did freeze your regulator it most likely was because of the Total Draw, generator, refigerator, stove, heater, hot water heater, or some combination of these, that caused the freeze. I doubt if the generator alone would have any effect
2004 Excursion 4x4
Old 07-10-2007, 05:33 PM   #5
Thank you for the responses. You've convinced me to stick with my original plan and go propane.
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 10:34 AM
Pressure Regulator pjtaia LP Gas, Piping, Tanks & Regulators 4 09-24-2002 07:26 PM
Disposable Propane Bottle Safety JaceBeck Our Community 6 07-02-2002 01:15 PM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
Propane valve leak Dbraw LP Gas, Piping, Tanks & Regulators 3 06-14-2002 06:12 PM
