Old 04-01-2012, 08:22 PM   #1
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
Burnt burner
Today I did an inspection on my Hydo Flame/Atwood heater Model 8531-II,in my 1989 Squarestream. I found the screen burnt of the burner.
WHY?
Could it be over fired because propane reg is bad giving me over 11 inches of water?
All other propane systems working OK
I will check propane pressure when I get new burner but would like to know if anyone has seen this before.
Jimmini :
AKA : TUMBLEWEED. Just an old buzzard with a itch to yonder.
Cowboys have a way of looking at things a little differently than most folks.Their wisdom is simple and more down to earth.
jimmini is offline   Reply With Quote
Old 04-11-2012, 06:26 PM   #2
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
April fool joke
WHY?
This was NOT a April fools joke.
And I got not 1 feed back on this, how sad is that?
IT DON'T TAKE A GENIUS TO SPOT A GOAT IN A FLOCK OF SHEEP.
Jimmini :
Old 04-11-2012, 06:45 PM   #3
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Hi Jim,
Possible that you could share a photo of what you're describing for all of us?
Thanks, Derek
Old 04-12-2012, 08:29 PM   #4
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
GOOD idea BUT I first will have to find the old one I have misplaced it I guess.
BUT new one will be here friday I hope then will post photo.
Jimmini :
Old 04-12-2012, 10:45 PM   #5
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Atwood
By using the search on the top bar you will find answers to most problems here.
If you highlight the Forums button on the top left, you will get a drop down menu with all thread subjects.
http://www.airforums.com/forums/f313...tml#post907064
Dave
Old 04-13-2012, 12:33 PM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
WHY?
Jimmini
The burners deteriorate with use. If the furnace is original to the trailer and has been used regularly it probably just reached the end of its life.
Before replacing it be sure to check the integrity of the heat exchanger as those usually fail around the same time.
Old 04-13-2012, 01:32 PM   #7
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Technically a higher water column would mean (in a non-blower assisted burner) it will fire to the rich side of air/fuel mixture, IF the air intake is optimized for exactly 11" water column, or 6 ounces of pressure per square inch fuel, then there isn't enough oxygen to cause it to over-fire temperature wise - and you'd have a reducing flame depositing excess carbon so its not an oxidizing flame eating your screen prematurely.
However with a fan assisted burner it could be a problem if they are depending on extra air making up for a higher back-pressure in a more complex heat exchanger. I'm a little surprised there is not a secondary propane regulator if it is that touchy... Just after you posted I looked for a splody parts diagram for your unit - clear as mud without having the unit itself in pieces... http://www.atwoodmobile.com/manuals/...0SP%201.08.pdf
Need a two burner stove top goshawks00 Stoves, Ovens & Microwaves 13 05-15-2012 07:14 PM
Water heater burner? Treyladut Water Heaters, Filters & Pumps 0 03-10-2012 05:09 PM
Save that Princess 3 Burner Stove Top Willyw Stoves, Ovens & Microwaves 2 03-05-2012 09:12 PM
No spark from stove burner pilot KerriO Stoves, Ovens & Microwaves 8 01-16-2012 10:37 PM
