Old 12-08-2013, 07:16 PM   #1
2002 27' Safari
Amarillo , Texas
Buddy Heater Install
Having a gas line installed to use for a Buddy Heater. The shop is telling me that the trailer appliances are "low" pressure and the heater is "high"
pressure. Requiring a new line by passing the regulator. True?
If this has been addressed before, please direct me to the post.
Thanks, Dan
DieselBreath is offline   Reply With Quote
Old 12-08-2013, 07:38 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
From the owners manual:
•GAS PRESSURE AT HEATER IS REGULATED AND FIXED AT 11” W.C. WHEN USING A REMOTE HOSE CONNECTION DO NOT REGULATE OR REDUCE PROPANE TANK SUPPLY PRESSURE TO HEATER!
MICHAEL
Old 12-08-2013, 08:56 PM   #3
Central , Mississippi
The Big Buddy has a low pressure input port and if I read the documentation correctly, it is rated for use in a RV if you follow their procedure
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 12-08-2013, 10:51 PM   #4
2002 27' Safari
Amarillo , Texas
I have a portable Buddy. This heater has a regulator built in. The Big Buddy would require an external regulator. Assuming a remote fuel source. Hope I have this right. Thanks for the input. Dan
