Old 07-14-2007, 04:14 PM   #1
healthchic's Avatar
2004 19' International CCD
haines city , Florida
Broken gas line for pilot light
I went to use my stove only to find the gas line to the pilot light broken at the fitting.Is the a common thing ? Any parts supply in central Florida or on line?
healthchic is offline   Reply With Quote
Old 07-14-2007, 04:31 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
For a 2004 Airstream? I would say it should not have happened so quick.
Inland Andy will log on Monday & mention running gear balance as a root cause for the failure.
It took my Airstream 39 years to have the problem you outlined. Central Florida has the parts. You may have to go to a new (to you) place to find them.
In my case, as I suspect as is yours too, the problem was an 1/8 inch aluminum line that broke. A refrigeration supply house sold me a new length of line & fittings to fix the problem. Even though I knew what I needed, I took them a sample of what I was looking for.
Tom
Old 07-14-2007, 05:08 PM   #3
healthchic's Avatar
Thanks Tom .
found part on line from repairclinic.com for $3.95 with fittings.
Gas appliances in an RV - routine maintenance lbrodsky General Appliance Topics 9 09-06-2007 03:17 PM
Outlet under sink, night light LI Pets Electrical - Systems, Generators, Batteries & Solar 5 09-24-2006 05:25 PM
Gas Detector winner Airstream Motorhome Forums 2 07-02-2002 03:59 PM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 03:37 AM
inside light lens' how to remove to clean Paul Daugherty Mechanics Corner - Engines, Transmission & More... 12 04-25-2002 10:51 PM
