Old 05-16-2015, 11:02 AM   #1
Ohiobrits's Avatar
2015 27' FB International
Howard , Ohio
Broiler - gas oven - how to turn on
The gas oven in our 2015 27FB has "broiler" on the oven dial. Is there supposed to be a flame at the top of the oven with this setting? The "broiler" setting does not appear to do anything - flame is still at the bottom of the oven same as when in bake mode.
2015 27FB International Signature "Danielle"
ProPride / 16" wheels / 600W solar / 864 AHr Lithium
Victron MultiPlus Inverter / BlueSolar / ColorControlGX / BMV 702
Porsche Cayenne Diesel
Ohiobrits is offline   Reply With Quote
Old 05-16-2015, 11:18 AM   #2
Ohiobrits's Avatar
Howard , Ohio
My wife figured it out. Light the oven pilot. Turn oven dial to "broil". Put the bread (for toast) on a baking sheet at the top of the oven. The side facing down gets nicely brown after a few minutes, flip the bread and repeat.
Toast!
Old 05-16-2015, 11:45 AM   #3
1974 Argosy 20
Kooskia , Idaho
Yes, all the broiler setting does is to keep the burner on full time, not controlled by the thermostat. In general there is enough space below the lower burner on the oven floor to slide a pan of toast or meat in so it is exposed to the radiant heat from the flame which is above it. There is not a lot of clearance for thick things, but toast etc will work.
Old 05-16-2015, 05:30 PM   #4
Ohiobrits's Avatar
Howard , Ohio
Idroba, thanks, had not thought of doing that.
Old 05-17-2015, 10:59 AM   #5
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Not a broiler in the conventional sense.
TinCan
graysailor is offline   Reply With Quote
Old 05-17-2015, 11:56 AM   #6
Tincampers's Avatar
Sneedville , Tennessee
Ok, quick someone calculate how much propane is used making toast...��
Tincampers is offline   Reply With Quote
Old 05-17-2015, 12:09 PM   #7
belen , New Mexico
actually it sounds like old school gas broiler! Elec ovens use the top rack. Older gas ovens have a drawer under the flame. Rvs it's just a space under the flame tube.
alantbird is offline   Reply With Quote
Old 05-17-2015, 01:39 PM   #8
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
Works great for making nachos!
robert claus is offline   Reply With Quote
Old 05-17-2015, 04:16 PM   #9
richinny's Avatar
2011 34' Classic
i think i'd just hold the toast with tongs over a top burner.
Ricky
Old 05-17-2015, 04:49 PM   #10
1974 Argosy 20
Kooskia , Idaho
Very little. Propane has about 90,000 btu per gal. the burner in the range is probably 9000 to 10,000 btuh. So might take 1/10 gal per hour of use. Lets say you run it for 10 minutes, that is 1/6 th of an hour.
1/6 th of 1/10 th is not much.
My head hurts now.
Old 05-17-2015, 10:08 PM   #11
TinCan
graysailor's Avatar
2016 30' Classic
I just use a toaster.
TinCan
Old 05-18-2015, 03:51 AM   #12
Tincampers's Avatar
My head hurts now.
Sorry about the headache. Thanks for the computations!
Old 05-21-2015, 04:46 PM   #13
Ohiobrits's Avatar
Howard , Ohio
Yep a toaster would be MUCH easier than dealing with the pilot light on the oven. We have thought of getting a small 2 slice unit but thinking about it was a far as we got.....
Then we had a hankering for toast last weekend and no toaster onboard hence the quest to figure out the "broiler" setting.
Old 05-21-2015, 05:06 PM   #14
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Go watch Downton Abbey - the episode where the first toaster arrived and the butler thought the house had been set afire. His second reaction... that's a solution looking for a problem, what's wrong with doing it in the oven?
We always had toasters - yet whenever there was a slumber party all of the moms made toast for half a dozen girls - under the broiler. Even into the LATE 70's, four slice toasters were generally sold to the commercial market only.
Look for a camp stove toaster - sits on a burner and does toast one side at a time. Stores in the space of a dinner plate, is dirt cheap.
https://www.google.com/search?q=camp...ml%3B440%3B440
Paula
Google Turn-by-Turn Navigation techiej Electronics & Connectivity 19 12-27-2012 05:55 AM
Broiler in oven and such BessieB Stoves, Ovens & Microwaves 1 09-06-2012 11:26 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
Need pictures of gas line for Magic Chief oven gas connection dghaas General Repair Forum 1 01-30-2009 09:04 PM
Magic Chef Broiler Pan walter1 Furnaces, Heaters, Fireplaces & Air Conditioning 5 12-16-2005 03:45 PM
