Old 07-08-2014, 12:07 PM   #1
1975 Argosy 28
Montreal , Quebec
Bowen water heater replacement.
Allo
Sadly the hot water tank in my 1975 argosy is cracked and must be changed...
The rest of the model no.G6A2 still functions, the pilot and the burner seam to work just fine... Im a bit confused on what to do, should i change just the tank and how easy is that?? or should I buy and all new unit?
BTW. when i light up the unit the was no water in it, the previous owner had bypass the water from the cracked tank... the flame after a while just went out... hope i did not break anything "Newbie".
many THANK'S, MERCI.
rbn9 is offline   Reply With Quote
Old 07-08-2014, 12:11 PM   #2
1974 Argosy 20
Kooskia , Idaho
In general it is less easier to just replace the entire unit than repair it, especially on a 39 year old water heater. The repair cost will be very close to that of a new unit.
Old 07-08-2014, 02:00 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I have a '74 Argosy and would recommend a new "basic" unit.
The most difficult part will be the gas line. The newer models are not in the same place. But close.
The Atwood 6 gallon model is the replacement for the old Bowen.
Old 07-08-2014, 02:05 PM   #4
1975 Argosy 28
Montreal , Quebec
Thanks for the reply and advice )
I will replace the hole unit
THANKS,
Old 07-08-2014, 02:20 PM   #5
1975 Argosy 28
Montreal , Quebec
I found this online Atwood Propane Water Heater, 6 gal, Pilot G6A7 Atwood Propane Water Heater, 6 gal, Pilot G6A7
I think its the proper replacement, are there any special tool to be bought for the task? Do I have to chage the front panel?
thanks for the wisdom...
Old 07-08-2014, 02:40 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You may need a tubing bender and flaring tool for the gas line. It's been 4 years since I replaced mine. As I recall I replaced the gas line from the water heater to the gas shut off valve below the trailer.
Also wrenches to fit the gas line fittings. Always use 2 wrenches when loosening or tightening gas line fittings.
The existing cover will work.
I installed wooden blocks between the inner and outer skins around the opening in order to get a firm attachment of the new heater.
Caulk will be needed to seal around the edges. I used a product called LEXELL. It works great and is still pliable after 4 years.
Do not remove the styrofoam from the water heater. It should be installed with this in place. It serves as insulation to prevent heat loss.
This would be a convenient time to install a bypass valve system for winterizing.
Old 07-09-2014, 11:11 AM   #7
1975 Argosy 28
Montreal , Quebec
WOW...
Thanks TG Twinkie for all that infos, this forum is a absolute gold mine...
MERCI...
Old 07-09-2014, 03:42 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You are welcome.
I worked in Baie-d'Urfe in the early 90's. spent almost a year there.
I am somewhat familiar with the area.
My wife is Canadian. Met her in Vancouver over 20 years ago.
It's probably more than you wanted to know.
If you have more questions. Help is here.
Need a Water heater Bowen replacement Russ G Water Heaters, Filters & Pumps 1 04-17-2013 09:12 PM
best (easiest!) '77 Bowen water heater replacement? JohnGalt48 Water Heaters, Filters & Pumps 5 09-28-2009 03:11 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
Replacement for Bowen water heater? 63air Water Heaters, Filters & Pumps 5 07-19-2005 09:17 AM
