Old 03-03-2013, 04:39 PM   #1
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
My project Argosy is coming to a close and I was missing a few bits, including the LP tanks. I picked up two sets of Worthingtons this weekend...two big ones (10gal), and two small ones (7.1gal). Which ones would you all use? I plan on updating, polishing and selling the remaining set.
Phrunes is offline   Reply With Quote
Old 03-03-2013, 04:46 PM   #2
cameront120's Avatar
1972 25' Tradewind
Which ones would you rather carry around when they're full? I like my 30 pound tanks and don't think I'd want bigger.
North Vancouver, BC
Old 03-03-2013, 04:51 PM   #3
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
We typically take 2 week long vacations and have 4 kids still at home under 10 years old...does this change the weight vs. useage equation regarding the 30lb/40 lb tanks?
Old 03-04-2013, 10:22 AM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Big ones or little ones...which is better?
Greetings Phrunes!
I have the 40-pound Worthington Aluminum LP tanks on my Overlander and am thrilled with them! They permit greater flexibility to shop around for the best price on refills, and most times, I am able to wait to refill until I am in familiar territory. They do not seem to be that much heavier than the 30-pound steel tanks that they replaced. The only down-side is that they are tall enough that they interfere with opening the front window fully . . . moving the LP Tank mount ahead on the hitch would solve the problem on my Overlander, but since I use air conditioning most of the time when I am on the road it hasn't proven to be an inconvenience.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 03-04-2013, 11:28 AM   #5
1974 Argosy 20
Kooskia , Idaho
The 40# tanks when full would weigh about 30 pounds more than the smaller ones. (10 x 2 + estimated 5 pounds extra weight for each tank). That is not much more weight to carry.
I agree with Kevin Allen, the extra capacity gives you more time to find a refill at your convenience and maybe at a lower price.
Old 03-04-2013, 01:10 PM   #6
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
That is kinda the direction I'm leaning 40#.
I'm edukatin myself on ops valves at the moment.
Old 03-04-2013, 01:51 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
Phrunes
Weight .... Rule of thumb comparing the weight of full tanks is that aluminum is lighter than the next size smaller steel tank. I have 40# aluminum tanks and find them to be manageable.
Exchange... There are some campgrounds around here that have 20# and 30# steel tank exchange, but not 40#, and not aluminum. So the availability of tank exchange service at campgrounds that don't offer propane fill service might be something to consider.
Use... As a practical matter if you camp 30 days a year or fewer the only way you can use up a pair of 30# tanks is either by running the fridge while storing your trailer or by running the furnace extensively. Or a bonehead move like leaving the water heater on in storage (done that). So the extra capacity will only help you if you run the fridge in storage or camp in cold weather.
Cold... Another fact to consider is that the larger furnaces require enough propane flow that, in really cold weather, you can't use the last of the propane. So if you do any winter camping with temperatures well below freezing you would want the 40# tanks unless you bring a 100#er with you on those trips.
Old 03-04-2013, 02:39 PM   #8
2008 16' Safari
Destrehan , Louisiana
I like the small size LP tanks that are used for gas grills. You can swap them out at any store that has a tank exchange. It's fast and cheap. No need to look for a LP filling station.
dlb435 is offline   Reply With Quote
Old 03-04-2013, 03:02 PM   #9
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
I have aluminum Worthingtons that I will be polishing.
Old 03-05-2013, 10:47 AM   #10
blickcd's Avatar
Milford , Ohio
My trailer came with twin 30 lb tanks and they work fine for my needs. Mostly weekend trips and maybe gone for a week twice a year. If I were boondocking a lot or full timing I might consider the 40 lb tanks.
blickcd is offline   Reply With Quote
Old 03-05-2013, 11:44 AM   #11
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
You've got to lift them when full, and as I get older I appreciate the 30 lb tanks.
doug k
Old 03-05-2013, 12:41 PM   #12
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Are the 40 pound aluminum tanks just taller or also larger in diameter than 30 pound steel tanks?
Old 03-05-2013, 03:20 PM   #13
1988 32' Excella
Robbinsville , New Jersey
Just taller, same diameter as 20lb and 30lb tanks.
Old 03-05-2013, 07:46 PM   #14
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
I just had a thought...after polishing them, which I started today. The big tanks will be like a full length mirror, versus the smaller tanks being like a medicine cabinet mirror...hmmmm I could check my campin attire in the big ones. Decisions, decisions.
