Old 03-05-2013, 08:54 PM   #15
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Big ones or little ones...which is better?
Greetings Phrunes!
Originally Posted by Phrunes View Post
I just had a thought...after polishing them, which I started today. The big tanks will be like a full length mirror, versus the smaller tanks being like a medicine cabinet mirror...hmmmm I could check my campin attire in the big ones. Decisions, decisions.
The photo below show the twin 40-pound Worthingtons on my '64 Overlander shortly after the trailer and tanks were polished by P and S Trailer Service.
Good luck with your decision!
Kevin
P.S.: The tanks were "mirror" polished while the Overlander received and "Original Sheen" polish with Plasticoat.
Kevin D. Allen
AIR #827
Old 03-05-2013, 09:41 PM   #16
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Originally Posted by overlander64 View Post
Greetings Phrunes!
Kevin
Wow! That looks great! If you don't mind my asking...what is a reasonable price for the tank polishing? I'm getting a mirror finish to mine, but I'm having trouble on the inside areas near the fill valve. Honestly, with the trailer strip and polish underway, I would just as soon outsource the tank polishing.
Matt
Phrunes is offline   Reply With Quote
Old 03-06-2013, 11:48 AM   #17
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings Matt!
Matt
I haven't heard anything about what the cost might be for polishing just a pair of LP Tanks. When mine were done, my Overlander was already in the shop for polish and Plasticoat, and the tanks were included as a part of that job. The tanks were new at the time as I was replacing the steel tanks that had been installed on the coach prior to my purchase . . . I don't know whether a professional polisher would attempt polishing tanks that had been filled or had LP in them.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 03-06-2013, 12:09 PM   #18
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Greetings Matt!
Kevin
Kevin, I've been polishing mine for the last few days assuming they were empty...until I hit the valve and heard the hiss over the buffer. Holy Moley! So, my plan is to have new OPDs put in first, because the tanks will be purged...then resume polishing. Ideally, I will have someone else, a professional, assume the polishing duties if it is not too costly. Thanks for your reply by the way!
Old 03-06-2013, 02:33 PM   #19
JimGolden's Avatar
1977 31' Excella 500
I have twin 40lb aluminum tanks on my 34' Avion and like them a lot. Never run out of gas!
- Jim
JimGolden is offline   Reply With Quote
Old 03-06-2013, 03:59 PM   #20
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
Matt if it comes down to what is most convenient stick with the 40's. So then now that that's settled I'll buy your 30's as we are more weekend campers and are looking for some tanks to polish up once I'm done polishing the Safari. Good luck,
Barry & Karen
goshawks00 is offline   Reply With Quote
Old 03-07-2013, 07:36 AM   #21
Skater's Avatar
1995 30' Excella
Bowie , Maryland
We have two 30 lb tanks. I'm about to fill one and probably won't need to fill that same one again until the fall. We don't use much propane spring, summer, and fall.
In winter we use a tank every 2-3 days, around freezing temperatures.
I probably wouldn't bother with the 40 lb tanks unless I got a GREAT deal on them and a new tank cover. They're that much heavier as someone pointed out, and the benefits (probably an extra day or two in winter) probably aren't worth the hassle and expense for us, given we already have two good 30 lb cylinders. It might be a different result if I had to buy two new ones, though.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
