Old 05-23-2014, 10:19 AM   #1
jbwillingham's Avatar
Richardson , TX
Best Replacement Furnace
I've got a '71 Tradewind Twin that I purchased and the PO had removed the furnace and was just using an electric space heater. Can anyone suggest a good replacement furnace?
I think it originally had a Suburban NT-16. Should I just go with the newer NT-16SEQ? The trailer is only 25' feet and it doesn't look like the heat was ducted, so I am thinking of going with the same ductless set up.
jbwillingham is offline   Reply With Quote
Old 05-23-2014, 10:38 AM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
I could be mistaken but I believe your trailer would have come with a ducted NT-30.
An NT-16 is really too small. You'd have enough heat down to around 32 degrees, and below that, it wouldn't keep up, especially in the wind and at night.
In general, the Suburban NT series are the best available fit for the original location. If you are in fact going to be using a smaller unducted furnace you could consider the Atwood Everest also. It has a lower amp draw if that's important to you. I don't think there's much difference in quality or price.
Old 05-23-2014, 10:43 AM   #3
The original should have come with an NT-30.
That's what a replacement should be.
Old 05-23-2014, 10:49 AM   #4
Richardson , TX
Maybe so. I am kindof flying blind because not only was the furnace removed, but the entire cabinet assembly was gone. I do still have the water pump, kitchen sink and oven, but the furnace and all the cabinets were gone, as well as any ductwork if there was any.
I don't see any evidence of ductwork. There are no cutouts in the 1/4" bulkheads where the ductwork would have gone back to the twin bed area or into the rear wetbath.
The service manual I have for the '72 version shows a diagram for a ducted system. Maybe '71 was done differently.
Old 05-23-2014, 11:58 AM   #5
Richardson , TX
In looking at my Owner's manual, it says a 23-25 ft. AS would have a 22,000 BTU furnace. Would that have been the NT-22 then?
Old 05-23-2014, 12:35 PM   #6
Yes, but you can kick it up to 30,000 for very little more money, and they are the same size.
Old 06-17-2014, 10:19 PM   #7
Kei
Hope
Kei's Avatar
1971 23' Safari
Anthem , Arizona
Suburban 22 furnace and ductwork pictures
Here is a link to pictures of the the furnace I just removed from my '71 23' Safari Twin. '71 23' Safari Twin Suburban 22 Furnace
If you want, I can send you picts of the ductwork layout and even sell you the galvanized ductwork (I'm doing a full renovation, but don't know what I'll use to heat with yet...)
"Hope" - '71 23' Safari Twin Land Yacht
Anthem, AZ
Kei is offline   Reply With Quote
Old 06-17-2014, 10:28 PM   #8
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
KEI, here is what I did for a furnace. It has been tested to 9 F, worked great. Click image for larger version
Name:	ImageUploadedByAirstream Forums1403062016.780833.jpg
The pic is of the TV, but the furnace made the frame.
Old 06-17-2014, 10:39 PM   #9
Kei
Hope
Kei's Avatar
1971 23' Safari
Anthem , Arizona
Make & Model?
Originally Posted by J. Morgan View Post
KEI, here is what I did for a furnace. It has been tested to 9 F, worked great. Attachment 214439
J. Morgan,
Very nice! Who is the manufacturer and the model? (I really like the modern approach to heating the AS).
Anthem, AZ
Old 06-17-2014, 10:54 PM   #10
Richardson , TX
I just found your posts today. Unfortunately I already purchased a new unit and decided to go with a ductless unit.
Old 06-18-2014, 12:53 AM   #11
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
It is a Williams direct vent wall furnace,
http://www.alpinehomeair.com/viewpro...ions_brochures
It is a residential unit, but I used it anyway. I bought it because it only needs a single two inch diameter vent tube for intake and exhaust.
I was worried about its listed BTU capacity, but it heats my trailer well and quickly even when it was very cold in the single digits and low teens. It is quiet and effective and works while I tow.
It was white as pictured in the link but I painted it. It does require 120 volts though. Not a real problem for me I run it through an inverter like most everything else in my trailer.
? best - Atwood or Suburban Furnace? prhamilt Furnaces, Heaters, Fireplaces & Air Conditioning 12 05-09-2015 11:33 PM
best gas furnace for 24' Tradewind? SpaceEgg Furnaces, Heaters, Fireplaces & Air Conditioning 15 12-17-2010 04:37 PM
Best Replacement for Furnace,Water Heater, and Range briheath Furnaces, Heaters, Fireplaces & Air Conditioning 6 05-18-2009 06:47 PM
Best replacement for '63 Trade Wind International furnace Grand Master Furnaces, Heaters, Fireplaces & Air Conditioning 2 11-12-2007 03:28 PM
Best brand Furnace? 65 overlander Furnaces, Heaters, Fireplaces & Air Conditioning 6 02-14-2006 08:55 PM
