Old 05-20-2019, 02:27 PM   #1
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
Best LPG Monitor System
I have two (2) 30lb. Aluminum tanks. Is there a good monitoring system I can use? Up to this point I just keep an eye on them, but I'd like something better that I can read from my truck or the AS cabin.
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500 Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Old 05-20-2019, 03:13 PM   #2
egraham's Avatar
2016 28' International
Birmingham , Alabama
Propane tank gauge
http://www.airforums.com/forums/f543/propane-tank-gauge-195372.html
egraham is offline   Reply With Quote
Old 05-20-2019, 03:15 PM   #3
2007 22' International CCD
Yup. That works, as many have reported. The tank tire ring also positions the tank properly and help reduce rust or corrosion on the tank bottom ring. Readout can also be on your phone or a stand-alone display inside the trailer.
Some of my tanks also have built in mechanical gauges, but you have to open the cover to see them. DW wonít like me putting windows in the tank comer....
Old 05-20-2019, 04:53 PM   #4
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
The OP has aluminum tanks which prevents the use of the magnetic sensors. I don't know of any units that will work with aluminum tanks.
Old 05-20-2019, 04:55 PM   #5
The magnets just stick them to a steel tank. There is also a set of rubber pads in the kit to hold the sensor against the bottom of an aluminum or fiberglass tank as well.
The sensor uses sound pulses to detect propane level.
Old 05-20-2019, 05:11 PM   #6
Hans627's Avatar
Ah, I wasn't aware that provisions have been made to use the sensors with aluminum or fiberglass. Thanks for the info.
Old 05-20-2019, 08:55 PM   #7
As far as I know the tank type does not matter much. Check the manual and the manufacturer website to double check. My tanks are steel...
Old 05-20-2019, 09:00 PM   #8
Re-Pete's Avatar
1992 29' Excella
That's really good to know. I was have not seen that information before. As you mentioned in your last post, I'll check the manual and the website. Thanks
Pete
Virginia Beach, VA
Old 05-20-2019, 09:03 PM   #9
Re-Pete's Avatar
1992 29' Excella
My thanks to everyone who replied.
Pete
Virginia Beach, VA
Old 05-20-2019, 09:30 PM   #10
Was just looking at website. Canít find a definitive answer on aluminum tank usage. Might be a good idea to call them. Theoretically they should work if the rubber covered sensor is in firm contact with a metal tank bottom.
Old 05-21-2019, 09:36 AM   #11
PSU1981
PSU1981's Avatar
2015 27' Flying Cloud
Spring , Texas
PSU1981
So I performed a little test last weekend to see how accurate the Mopeka system is using a scale to measure the weight of each tank.
Empty Steel 30 lb Tank = 24 lbs
Full Tank = 54 lbs
Tank 1 37.8 lbs = 46% Mopeka reading = 55%
Tank 2 40.2 lbs = 54% Mopeka reading = 48%
So accuracy was +/- 6 to 9 %
PSU1981 is offline   Reply With Quote
Old 05-21-2019, 09:39 AM   #12
PSU1981
PSU1981's Avatar
Spring , Texas
I decided to go with an old system - open 1 at a time & when it’s empty - switch to other tank & fill the 1st - this way you always have at least 1 full tank...
Old 05-21-2019, 11:07 AM   #13
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I have aluminum 40# tanks. No sensor attachments so when I suspect I'm getting low I simply remove the cover and lift and shake them. Works for me and margin of error is pretty low.
Originally it came with 30# aluminum tanks each with a dial gauge and a lug to attach the wire.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 05-21-2019, 11:25 AM   #14
2006 28' International CCD
Saint Paul , Minnesota
Pitch as in music. When propane tank is full, knock on it with your knuckle. It makes a sound, F# maybe (App tuner on iPhone, "Total Energy Tuner" for instance, will tell you). Tap when tank is empty, different pitch, E perhaps. Different tanks different pitches. You'll soon know yours. Perfect pitch helps (I don't have it) but the tuner app works perfectly. Most of us have two tanks. One empty, one full produces a minor third. Go from there. It works and with the app it's foolproof.
Mhphhoward is offline   Reply With Quote
LPG monitor hickory LP Gas, Piping, Tanks & Regulators 3 08-08-2016 09:08 PM
LPG Sensor - Which to use with SeeLevel 2 System? trekerboy Electrical - Systems, Generators, Batteries & Solar 5 01-02-2015 09:58 PM
Does the Micropulse Monitor Panel Monitor LP? KJRitchie LP Gas, Piping, Tanks & Regulators 5 03-21-2013 02:20 PM
Tank monitor system on the fritz mhilley Fresh Water Systems 7 11-27-2011 08:57 AM
Upgrade to a new system monitor? GoNomad Electrical - Systems, Generators, Batteries & Solar 7 10-27-2006 07:02 AM
