Old 08-23-2017, 12:25 PM   #1
2017 27' International
Box Elder , South Dakota
battery indicator/propane problem
When no shore power or generator, my battery indicator says 9.1. In that state: 1. The inverter circuits don't work. (The inverter switch is on).
2. The propane mode reefer won't cool, even though the LP indicator is on.
3. The LP water heater red light comes on after a while.
4. The furnace and the stove do work.
5. All the lights, radio, water pump do work, but weakly.
With my 30 amp generator running, the battery indicator says 13.5 and everything works fine, air, heat, TV, and microwave.
I really don't know what to think. Any insights appreciated, thanks. My best guess is that the battery needs to be fully charged or at a minimum threshold for everything to be fully functional, and that the reading of 13.5 when the generator is running is misleading. One more question, will the generator eventually charge the battery? I am running the generator now to see if anything happens.
2017 27 foot FB International Serenity.
alphamale49 is offline   Reply With Quote
Old 08-23-2017, 12:39 PM   #2
richw46's Avatar
Lexington , Kentucky
At 9 volts, you battery is too low to operate most of the items you include, they all have a minimum operating voltage and will shut down below that threshold. At 9 volts you have also damaged the battery/batteries, they should not be allowed to discharge below 12.0 volts.
When you run the generator you provide voltage sufficient to operate everything and to charge the batteries (13.5 volts). Whether or not the batteries will recharge depends on how damaged they are. Most likely, if you didn't run the batteries down to 9 volts, then you have one or more bad cells in the batteries and they need to be replaced. Take the batteries to a shop to have them checked.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 08-23-2017, 01:00 PM   #3
dmbecke's Avatar
Des Peres , Missouri
Agree and we have seen dealers delivering less than good batteries in new trailers since they sit on lots and may not get charged
dmbecke is offline   Reply With Quote
Old 08-23-2017, 04:16 PM   #4
Thank you and very interesting. I was also wondering if a bad converter or converter fuse would interfere with recharging the batteries.
Old 08-23-2017, 04:26 PM   #5
richw46's Avatar
I'm pretty sure your converter is protected by a circuit breaker, not a fuse. If the breaker was flipped you wouldn't have any AC power. The converter takes AC and makes DC to power all the DC devices (lights, fans, etc.) without using battery power. In Airstream trailers there is a switch by the door: Use/Store. I don't know where that is in the Interstate.
If the Use/Store switch is in Store and you're connected to a power source (shore power or generator) you will have DC power to all the devices but your battery won't get charged. It needs to be in Use to charge them.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 08-23-2017, 04:47 PM   #6
Thank you. The generator raised the battery voltage some what, but very slowly. I just attached the 7 way electrical cable to the truck and I am letting it run. The voltage is now up to 12 after just a few minutes! Impatiently, I tried the inverter for a moment, and it now is working. I'll continue to charge from the truck to see how high I can charge the batteries.
Old 08-23-2017, 05:18 PM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The OP has an International, not an Interstate. Normally that correction has to be made the other way, with people mistaking an Interstate for an International. It's actually nice to see that the mistake can happen both ways.
WBCCI #1105
TAC LA-4
I don't have an anger management problem. I manage to remember exactly what everyone has done to make me angry!
Old 08-23-2017, 05:33 PM   #8
Half a Rivet Short
Carlisle , Pennsylvania
Hi
If your battery voltage goes up to 13.5 when the generator is running, that suggests that the charging circuit(s) are working. Best bet is that you have at least one shorted cell in your batteries.
uncle_bob is online now   Reply With Quote
Old 08-24-2017, 09:58 AM   #9
richw46's Avatar
D'oh!
My dyslexia raises its ugly head. Thanks, Protagonist
-Rich
Rich & Yvonne
2004 4Runner SE
Old 08-24-2017, 10:03 AM   #10
richw46's Avatar
It will really depend on if the batteries can hold the charge. After they reach charged (12.7) let them sit for a couple of hours and take a reading. If they are wet cell and you can access the plates through the filler caps, a hydrometer will tell you if you have a bad cell. [If they are sealed then just take a voltage reading.]
Another fairly good tool is a load tester. I got one from Harbor Freight. It's cheap but will give you an idea of the battery's state under load. I think with the 20% off coupon it was less than $20 and you get a free something too.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 08-24-2017, 04:16 PM   #11
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi Alphamale49,
Congratulations on your new Serenity. Please call our Customer Service and Technical Support team if you continue to have issues with your new Airstream. We're here to help!
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 2.
AirstreamInc is offline   Reply With Quote
Old 08-24-2017, 06:55 PM   #12
Long Island , New York
Battery issues are being discussed in the thread with my recent post quoted below, and you might want to read up at the Battery School link and other battery failure threads.
Good luck,
Peter
[click on arrow in quote to go there]
Originally Posted by OTRA15 View Post
Yup that will happen with the basic charger supplied by AS. Most folks upgrade to 4-stage charger, and get new batteries. If your AS is still under warranty, you could take the batteries to an Interstate dealer (assuming this is the correct brand of battery) and have them tested. They may be toast or salvageable. You might want to read your AS owner's manual also, as some preventative maintenance can forestall problems like this.
Good general reading: http://www.batteriesnorthwest.com/ba...hool.cfm?TID=0
Lots of threads on battery failure issues.
Battery forum: http://www.airforums.com/forums/f449/
Threads:
http://www.airforums.com/forums/f382...ay-169288.html
http://www.airforums.com/forums/f449...ud-165144.html
http://www.airforums.com/forums/f382...or-170703.html
http://www.airforums.com/forums/f37/...es-170411.html
http://www.airforums.com/forums/f540...es-170571.html
http://www.airforums.com/forums/f516...on-169925.html
http://www.airforums.com/forums/f449...lp-169693.html
http://www.airforums.com/forums/f317...ge-170153.html
http://www.airforums.com/forums/f449...or-170148.html
http://www.airforums.com/forums/f449...ns-170201.html
That should be enough reading material for the night!
Good luck,
Peter
Old 08-25-2017, 12:38 PM   #13
Turned out the batteries were dead. Could not hold a charge. I replaced them. Thanks all.
Old 08-25-2017, 01:22 PM   #14
Thanks for the update. Hope you will seek compensation from the dealer/AS.
Capacity Indicator - Propane Gas eliasurbina Sprinter and B-van Forum 20 04-10-2013 04:03 AM
Electronic Propane Level Indicator Bigventure LP Gas, Piping, Tanks & Regulators 4 11-28-2009 07:09 PM
"Power On" indicator davidz71 Electrical - Systems, Generators, Batteries & Solar 23 09-15-2005 09:52 AM
Battery indicator in CCD, Acurate? crazylev Batteries, Univolts, Converters & Inverters 11 10-07-2004 09:35 PM
Battery problem or converter problem Paul Daugherty Airstream Motorhome Forums 31 07-01-2003 06:16 PM
