Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 09-12-2019, 06:16 AM   #1
Basic Fridge Question ...
I have a 2002 classic with orig Dometic fridge. I have attempted to clean and this is the size of the flame. Is that reasonable?Click image for larger version
umasslax is offline   Reply With Quote
Old 09-12-2019, 07:13 AM   #2
dznf0g's Avatar
Oswego , Illinois
Is it not cooling? I see yellow residue on the burner. This probably indicates a refrigerant leak. The flame looks a bit small, but pics of fire can sometimes not show the top of the flame.
-Rich-
Old 09-12-2019, 08:02 AM   #3
1986 31' Sovereign
Miami , Florida
Yep. Just swapped out my burner and it looks the same. Reefer is cooling well. The flame exhausts up the tube above it and the hot combustion gasses heat the adjacent boiler.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 09-14-2019, 10:46 AM   #4
Takes forever and does not seem to cool well. When I run it on electric it cools just fine and ice is able to be made. The LP just wont do the job. Pressure with in the line serves an adequate supply to the range. Just squat to the fridge. Next step?
Old 09-14-2019, 10:50 AM   #5
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Check (and clean) the entire stack / vent path all the way to the outside world. You may have something fairly high up blocking things. If there is nothing obvious, a good blast with a compressed air hose is the next step ( to get things you can't easily see).
Old 09-14-2019, 01:31 PM   #6
Sag Harbor , New York
^^^^^ x2
I have a 2002 classic with orig Dometic fridge. I have attempted to clean and this is the size of the flame. Is that reasonable?Attachment 351978
Make sure the flue vent pipe going up is not crimped or dented. Does the flue go up through the roof? Look carefully for bird/spider/insect nests inside the flue cap on the roof [ladder, flashlight, small tube-cleaning brush/etc.] With the fridge burning propane, that roof cap should get too hot to touch if the exhaust gases are flowing freely IMO.
The performance on electric and propane should be similar IMO.
How about the fresh-air ventilation screen on the exterior access door? Is enough fresh air getting in for proper combustion? Try propping that access door up, and see if that improves things on propane IMO.
Peter
Old 09-17-2019, 04:58 AM   #7
2016 16' Sport
Miami , Florida
How do you know the gas has an “adequate” supply? I have found that the flame could look normal and wile other appliances were able to function not having adequate LP pressure was enough to cause an inadequate amount of heat from the burner.
Shiny16 is offline   Reply With Quote
Basic question from a newbie ptbeth 1966 - 1968 Safari 2 11-13-2010 06:08 PM
Batteries..basic charging question Delaware Batteries, Univolts, Converters & Inverters 3 11-16-2009 01:19 AM
Basic battery question Woodywhite Batteries, Univolts, Converters & Inverters 6 08-29-2009 02:25 AM
Propane basic question Woodywhite LP Gas, Piping, Tanks & Regulators 10 07-29-2009 11:19 AM
Argosy Basic Brake Question uniquemicro Brakes & Brake Controllers 3 10-21-2008 07:57 AM
