Old 12-02-2015, 06:57 PM   #15
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Our 30# was consumed in about 4 days with temp near freezing and windy.. Rain also pulls more substantial heat than a breeze.
We added the reflectix to all windows and skylights... Big difference!!! Much warmer. Far less propane use.
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-03-2015, 09:43 AM   #16
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
The LPG furnace in our Airstream is rated at 30,000 BTU/hour. A pound of propane has roughly 21,000 BTU. In theory, a 30# bottle should feed the furnace for 21 hours non stop. From recollection, I think I got about 3-4 nights max out of a tank when it was getting into the 20ís overnight. I know it runs a lot when it's cold.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 12-05-2015, 12:17 PM   #17
2018 23' Flying Cloud
Eagle Creek , OR
Send a message via Skype™ to almcate
Part 3: interestinger and interestinger...
Okay, solved the low pressure. Rain, wind, significant chill, and being a bit "house" bound seems a more reasonable explanation to the sudden upsurge in propane consumption than a leak.
NOW, furnace fan again cycles on but burner doesn't ignite (again, and of course, on a Friday night). Couple on/off cycles on the thermostat and same result. Two hours later, furnace starts up. Then doesn't. Then does. Was thinking a bad thermocouple but I don't think they fail intermittently. Same with the thermostat. Good gas pressure and fire to burners and water heater.
Opening up the furnace enclosure (while it's working for now), as I expected, nothing jumped out as an obvious problem except that there were at least two dozen stink bugs nesting inside the space between the metal access door and the plastic component box door. An absolute explosion of the critters here in Oregon over the last couple months. Now me thinks, maybe this is just a couple suicidal stinkbugs crawling up into the combustion tube? Good dose of insecticide as a preventative, maybe? Thoughts, comments, howls of derision?
Sigh.
Question: better to be a successful pessimist or a failed optimist?
Al & Robin
2018 Airstream 23FB Flying Cloud
2015 F150 XLT 3.5L EcoBoost, 4WD
almcate is offline   Reply With Quote
Old 12-05-2015, 03:13 PM   #18
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
If you are not hooked up to 110v it may be a low battery. Our furnace won't light if the voltage is low. Fan starts when heat is turned on but the sail switch won't energize if blower is slow. Maybe a good cleaning of fan area and some lube on fan shaft may help.
Dennis
dennis3751 is offline   Reply With Quote
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Propane grills for low pressure connection lakeviewerie LP Gas, Piping, Tanks & Regulators 9 11-18-2012 06:22 AM
Water Heater Adjustment? Gas Pressure too low? chasrahm Water Heaters, Filters & Pumps 1 08-10-2009 10:27 AM
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 01:04 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
