Old 04-25-2016, 05:46 PM   #1
John Geisen's Avatar
2005 28' International CCD
Palm Beach Gardens , Florida
Angry Atwood LP Propane 1amp fuse?
Our Atwood LP Propane gas detector was defective (solid yellow with chirp every 30 seconds). Of course it was driving me crazy so after ordering a new one I cut the wires to the defective one. Now, I no longer have power to the new detector.
The wiring diagram from the manufacturer shows a 1 amp fuse but for the life of me I can't figure out where it is located. Since the detectors are hot wired back to the battery that was the first place I went but the only wire there is for the hitch. If it helps we have a 2005 28' CCD. Any help would be much appreciated.
John
John Geisen is offline   Reply With Quote
Old 04-25-2016, 07:37 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
John
Try looking forward where your DC bus bars are located. You will usually find a single in-line fuse holder for a glass-type tubular fuse that is wired directly to the hot side of the positive bus bar. This is one if the reasons that it is a constant parasitic load, as it is not part of the 'use/store' solenoid circuit that is disconnected when pin 'store' mode. It's powered all the time.
Old 04-26-2016, 05:42 AM   #3
Thank Lewster. I'm looking but without much success. Do you think Airstream would have a clue?
Old 04-26-2016, 05:52 AM   #4
lewster's Avatar
O would hope so, but no guarantees.
Old 04-26-2016, 06:07 PM   #5
Followed the Airstream protocol for requesting assistance. Within about 2 hours I received a reply from AS guiding me to the very front drivers side where they were even able to tell me the color of the wire. Fuse was clearly marked 1 amp. Replace it and all is good. I hope this might help anyone else with a 28' International and a blown inline fuse for their Atwood LP Gas Detector.
And Lewster, thanks for replying.
Old 09-24-2017, 06:11 PM   #6
Olympia , Arkansas
I also replaced my LP gas detector. I do not have power. I checked the fuses they look fine.
m4dball is offline   Reply With Quote
Old 09-24-2017, 06:17 PM   #7
Olympia , Arkansas
Originally Posted by m4dball View Post
i also replaced my lp gas detector. I do not have power. I checked the fuses they look fine.
Old 10-21-2017, 02:05 PM   #8
Olympia , Arkansas
Still trying to fix my LP gas detector. No power. Replaced the 1 amp fuse. Not sure where to go from there.
Propane Gas Detector Went off Last Week-Turns Out NOT the Propane breezyway Electrical - Systems, Generators, Batteries & Solar 4 08-16-2014 08:56 AM
Newbie Advice on Propane and Propane Accessories Socal1 LP Gas, Piping, Tanks & Regulators 1 07-15-2013 12:36 PM
Atwood water heater uwe Water Heaters, Filters & Pumps 5 10-03-2009 01:58 AM
Bowen/Atwood LP to Atwood LP/ELEC./DSI? 65 overlander Electrical - Systems, Generators, Batteries & Solar 9 12-05-2005 06:10 PM
Atwood HWH kntd Water Heaters, Filters & Pumps 4 01-14-2003 12:55 PM
