Old 09-22-2015, 01:54 PM   #1
Nugee's Avatar
2013 19' International
Pukekohe , Auckland
Atwood Heater
Hi, we have a 2013 Bambi here in New Zealand which we imported last year, we removed the air con unit as it wasn't able to be used here. When we removed the air con controls did we also remove the control for the Atwood heater as I can't find any switches to get it started?
Helen
Nugee is offline   Reply With Quote
Old 09-22-2015, 03:11 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My 2006 heater is controled by the AC digital thermostat control. I do not think that has changed.
MICHAEL
Old 09-22-2015, 11:29 PM   #3
Nugee's Avatar
Pukekohe , Auckland
Thank you I thought that had to be where it was, will have to try and add a new control.
Atwood water heater uwe Water Heaters, Filters & Pumps 5 10-03-2009 01:58 AM
Bowen/Atwood LP to Atwood LP/ELEC./DSI? 65 overlander Electrical - Systems, Generators, Batteries & Solar 9 12-05-2005 06:10 PM
New gaskets for Atwood 6 gal water heater j54mark Water Heaters, Filters & Pumps 0 01-03-2004 12:46 PM
Atwood Water Heater Thermistor Mike76251 Water Heaters, Filters & Pumps 2 01-01-2004 10:30 AM
Atwood Water Heater Parts? ViewRVs Water Heaters, Filters & Pumps 1 04-08-2003 08:13 PM
