Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 12-29-2014, 05:00 PM   #1
1978 31' Sovereign
1988 32' Excella
Linthicum , Maryland
Atwood G6A-7E smelling gas.
Had a leak in the Bypass valve connector(s). Replaced valve with a new, different type - no leak anymore, but there is a distinct smell of propane in the sleeping area (bed id on top of waterheater). In the process of replacing the Bypass valve - had to take the unit out. Is there any reason why we have the gas smell in the sleeping area?
RuneM46 is offline   Reply With Quote
Old 12-29-2014, 07:20 PM   #2
Wayward's Avatar
Broadway , North Carolina
Considering that you said you removed the water heater to replace the valve, the likely culprit is a leaking gas fitting at the water heater.
Did you try to tighten it a bit more?
If that is not it you need to track down the leak, starting at the water heater. You can use soapy water but one of these is must have tool....
2006 Safari SE FB
2000 F150 4.2L (retired), 2011 F250 6.2L, 2010 ML550, 2000 Excursion 7.3L
Broadway, NC
Atwood G6A-7 dlarrow Water Heaters, Filters & Pumps 0 07-31-2013 10:38 AM
Smelling the heat! Luftnoggin Furnaces, Heaters, Fireplaces & Air Conditioning 8 09-18-2011 10:55 PM
How to keep the Refrigerator sweet smelling when not in use Airperson Refrigerators 7 09-11-2011 06:36 PM
Atwood g6A-4E won't start stanh Water Heaters, Filters & Pumps 0 09-29-2009 02:55 PM
'93 Excella - Atwood G6A-7E binkers Water Heaters, Filters & Pumps 2 04-03-2008 09:58 AM
