Old 03-30-2015, 01:51 AM   #1
1954 22' Safari
Little Compton , Rhode Island
Are propane ice makers available?
We will be boondocking more and could really use some type of ice maker that doesn't require electricilty. We don't need a refrigerator, just a small ice maker. Is anyone familiar with a propane operated ice maker? I haven't had any luck searching the internet.
Collapso is offline   Reply With Quote
Old 03-30-2015, 04:17 AM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Ice cube tray in the trailer freezer?
I have never seen a stand alone propane powered ice maker. I have seen freezers, but they aren't what I would call portable.
Aaron
WBCCI #XXXX AIR #2495
Old 03-30-2015, 06:03 AM   #3
Skater's Avatar
1995 30' Excella
Bowie , Maryland
This page explains the lack of them. Basically, how are you going to mechanically dump the ice without electricity?
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 03-30-2015, 07:38 AM   #4
1974 Argosy 20
Kooskia , Idaho
I have been around for a long time but have never seen any such thing. It takes a lot of cooling power to make ice, and doing it with propane and absorption refrigeration is not a high cooling power situation.
This is one place that electric refrigeration is vastly more practical than propane.
Old 03-30-2015, 03:55 PM   #5
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
My experience. I installed a stock ice maker in the freezer of the "stock" Dometic 9 cu ft fridge in my new Classic. Not difficult to do, either. (Of course, I had to pull the fridge out to do it -- but I had to do that anyway to wire in solar and 30 Amp Magnum MSH inverter.) The ice maker came with everything I needed except the 1/4 inch tubing and valve required to tap into the water system. I did this a couple of months ago and the ice maker produces just as much ice in my Dometic as it would in the home refrigerator. Ice makers are built with a thermostatic control that activates a mold heater (to release the ice) and a mechanism to eject the ice from the machine. Of course, there's also a solenoid valve that opens to release the water into the ice maker. The main factor with an ice maker is "does the freezer get cold enough to produce ice." My Dometic most assuredly does this, either when I'm on 120V or propane. (I did wire the ice maker into my 120V inverter circuits so I can make ice when the Dometic is on propane.) I also have a switch to shut off the 120V if I'm boon docking and am majorly conserving power. Bottom line: if your Dometic is healthy and can do a hard freeze on food, it'll do a hard freeze on ice. Total cost of the ice maker and all the fixings is under $150.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Ice, ice Baby! hippiechick General Repair Forum 1 03-12-2015 06:42 PM
Any wine makers here? PaulnGina Off Topic Forum 18 01-16-2015 05:25 PM
Keurig Coffee Makers pappy19 Stella's Kitchen 30 01-27-2012 01:58 PM
WSJ - Economy Puts Tight Squeeze on RV Makers munimula Dollars & Cents 17 05-13-2008 07:17 PM
Coffee Makers Tarheel General Appliance Topics 7 12-01-2004 09:33 PM
