Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 02-06-2016, 05:55 PM   #1
1970 23' Safari
Elkhart , Indiana
Anyone ever install a grey water tank? I need advice or tips
So I decided to install just a grey water tank to shower and sink. I've never done this. I eliminated the black tank and plan on using a compost toilet. Anyways what are some experiences you guys have learned from? Or tips. I'm ordering the tank pre made with fittings in desired spots. What are some things I'll need as well? I have experience in PEX and plumbing. Thanks
Thill_1985 is offline   Reply With Quote
Old 02-06-2016, 08:04 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Hello Thill, welcome to all things Airstream. I see you are from the heart of RV manufacturing in this country. I'll bet your friends and neighbors are good sources of information and parts.
I installed new gray and black tanks under my 66 Trade Wind. It was a major project for me. I felt a gray water storage tank is required if you plan on traveling in your vintage Airstream. A "tote" tank as another alternative.
The belly pan comes off as well as the old insulation. While I was at it I cleaned and inspected the frame, then I painted it so it will last a little longer. I elected to hang my new tanks from the frame rails and drain the tanks from the street side below the frame rails as is the convention on most newer trailers. The toilet sits over the black tank of course, but I had to relocate the toilet.
I ordered my tanks from Inca Plastics in California. The tanks are about 26 gallon capacity. I also used their rubber grommets instead of spin welding threaded fittings to the tank. This allowed a bit more flexibility in running the drain and vent lines.
Here is a photo of the two tanks I purchased from Inca Plastics, then a photo of the tanks installed under the trailer subfloor, then a photo of the tank drain connection behind the rear wheels street side, and finally a photo of the toilet relocated between the frame rails.
So it all worked out and is now validated with three 1000 mile travels. Hope this helps.
David
Name:	1404 Waste Tanks See Level Senders.jpg
ID:	256921   Click image for larger version
Name:	1404 Waste Tanks Installed.jpg
Name:	1505 Home Street Front.jpg
ID:	256923   Click image for larger version
Name:	1408 Bath Vanity Sliding Doors.jpg
Old 05-16-2018, 09:14 AM   #3
1971 31' Sovereign
White Pigeon , Michigan
Neighbors!
I know this post was a while ago, but I am in the Goshen/Elkhart area and wondering how you decided to add your tanks. Thanks!
emilyweav is offline   Reply With Quote
Need window install tips tinbender Windows & Screens 23 04-19-2021 12:17 PM
Need advice grey and black tank and using MARINE TOILET Owengarrett General Repair Forum 1 03-11-2015 10:23 AM
Replacing black water tank with grey water tank cheetah1 Sinks, Showers & Toilets 25 10-02-2014 05:26 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Grey water tank install in Bambi II questions PA BAMBI II Waste Systems, Tanks & Totes 0 07-10-2013 01:38 PM
