Old 02-17-2011, 05:49 AM   #15
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Originally Posted by thecatsandi View Post
they work. I have had them for five years in both 30 and 40 lb tanks.
you use these horizontal tanks? Do you just ignore the float gauge?
robwok is offline   Reply With Quote
Old 02-17-2011, 06:56 AM   #16
Over59's Avatar
Putnam , Connecticut
Images: 37
Originally Posted by robwok View Post
I'm not begrudging VTS. Love those guys and they provide a great service. I just wanted to save money where I can. Amazon is not charging me shipping on top of a slightly cheaper price. I wanted someone to tell me why VTS was the right way to go. I'd rather go with the right solution, and I wanted aluminum tanks.
You bought a vintage trailer. Do it right or do it twice. There is nothing wrong with steel tanks. You can paint them silver, which is alot less work than polishing the al ones. You need to understand that the process is endless, the dollars are many, and the time three times what you would expect if you want a fully undated shiney trailer. I'ld suggest you use it for a season before doing much to it. You may find it is OK to have steel tank like stuff.
They have the best price I could find. Get the fuel gauge on at least one of the tanks.
Over59 is offline   Reply With Quote
Old 02-17-2011, 07:06 AM   #17
lewster's Avatar
Naples, FL , Hood River, OR
Just a quick rant on always searching for the 'best price'.
A company like VTS is a very valuable resource in this community. Send your business to the large retailers who might have the item a bit cheaper and watch the small, service oriented companies Like VTS, Inland RV and others whither away and disappear. Then you will have NOTHING except your cheaper price to thank!
And BTW, keep shopping at Wal*Mart while you're at it and support those good folks in the corporate board rooms who gleefully send US jobs to China and other offshore locations so they can increase their bonuses and the bottom line of their corporations while helping to decimate the US middle and working class.
Rant over!
Old 02-17-2011, 09:49 AM   #18
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Import Cheap
Lew:
I hear you!
Dave
Old 02-17-2011, 10:19 AM   #19
1972 25' Tradewind
Falling Rock , West Virginia
You can check the liquid level of any propane tank by pouring very hot water over the outside of the tank. A condensation line will appear, to give you a approximate level of liquid propane.
HillBilySkMo is offline   Reply With Quote
Old 02-17-2011, 01:34 PM   #20
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Rant over!
Rant away, I just sent VTS over $300 and plan to send a lot more. For something that is very standard, and that may be taking up a lot of room in their inventory, and be very heavy to ship, it was one of the few things I was looking elsewhere for. In hindsight, I probably should have kept the steel tanks and painted them. Certainly would have been much cheaper. I was kind of looking at resale value when considering the Aluminum. The old steel ones had just been sitting in a garage for a while. I could probably go back and get them, but it was an even split for the long term on how to handle those. And the savings I got from the aluminum tanks probably would have gone right back to VTS in the form of something or other since we are nuts about the Overlander.
I completely agree with the rant though. We buy our milk from a small family owned (meaning the teenage boys milk the cow) farm, and I do my best to support small family owned or regional businesses.
Old 02-17-2011, 01:41 PM   #21
x
XXXX , XXXX
So If I understand correctly the forklift tank is $150 and the VTS tank is $157. The forklift tank is a liquid tank which you will have to remove the liquid valve, plug the hole, buy a vapor valve and install it, remove the liquid guage and replace it with a vapor guage. That is if the forklift tank can be retrofitted to use with a vapor setup. I can't see how you would be saving any money at all. It would probably end up costing more.
wasagachris is offline   Reply With Quote
Old 02-17-2011, 01:44 PM   #22
alclad's Avatar
1961 16' Bambi
Wilmington , DE
Images: 46
we bought 2 20 pounders from vts, polished them .
they look like show chrome plating. worth the money. and they are from good people.
don
alclad is offline   Reply With Quote
Old 02-17-2011, 04:22 PM   #23
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Thanks. I'm not saying I was going to do it, I just wanted to know what people thought. I can build cabinets and furniture, and know all about banking, but all this RV stuff is new to me.
Old 02-17-2011, 04:23 PM   #24
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
don
Sounds good! I don't plan to do a lot of boondocking with 2 kids, so the 20 pounders may be just right.
Old 02-17-2011, 04:28 PM   #25
x
XXXX , XXXX
Rob I'll give you an example of consumption. I full timed in mine for 9 yrs and in the summer I could go 4 months on two 40 lbs tanks. I don't use the stove much and have the gas/elec combo water heater so it doesn't use as much propane and the gas only version. In the dead of winter the same two 40's would last one week. If you plan on doing any cool weather camping two 20's may not be enough. Why not wait and use the steel ones to find out your typical consumption rate before buying tanks that may be too small for you.
Old 02-17-2011, 08:02 PM   #26
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
I don't actually have the steel tanks anymore for one.... and I need to get them refitted. I think I may reach out to the guy that has them and see about maybe painting them for now.
amazon, aluminum
Rear Propane Tanks? Rob&Julie LP Gas, Piping, Tanks & Regulators 7 02-12-2011 05:38 AM
off the top of your head ... propane funkill LP Gas, Piping, Tanks & Regulators 2 02-08-2011 03:51 PM
Propane Tanks and gauges etc. SilverHoot LP Gas, Piping, Tanks & Regulators 13 02-05-2011 09:58 PM
Can not find Propane leak bmklawt LP Gas, Piping, Tanks & Regulators 15 01-02-2011 10:01 AM
