Old 01-20-2009, 06:05 PM   #1
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
Aluminum Tanks
Yippeee! we finally found a used set of 30lb Aluminum Tanks locally on Craigslist. They are from a 1971 Airstream and in pretty decent shape with some typical scrapes and scratches. We polished them up over the weekend and they look great. At $80 for both tanks and $60 for new valves we can live with some imperfections. Can't wait to see how they look on the trailer.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
LHall is offline   Reply With Quote
Old 01-20-2009, 06:45 PM   #2
cameront120's Avatar
1972 25' Tradewind
Congrats! We'll need pictures, of course.
North Vancouver, BC
Old 01-30-2009, 08:04 AM   #3
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
Once we get them installed we will post some new pictures. Hopefully this weekend.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
Old 01-30-2009, 08:22 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Can't wait to see them on your shinny trailer! Remember, they are going to be a couple of inches taller then the steel ones, mine were.
Richard
Old 01-30-2009, 08:26 AM   #5
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
If you remember, we have the small 20lb steel tanks currently and the aluminum ones are much taller. We plan to install them this weekend hopefully. We may have to replace the threaded rod .... not sure yet but we can't wait to see how they will look.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
Old 01-30-2009, 08:57 AM   #6
2002 25' Safari
Dewey , Arizona
Images: 62
I forgot, these will be much taller then.
Richard
Old 02-01-2009, 08:00 AM   #7
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
Pictures
They are much taller and went right into place. Everything mounted just as it is supposed to be. The are not perfect, but look much nicer than the Home Depot Tanks we previously had mounted on there. Here are some pictures. We are working on the second pass of polishing this weekend.
ID:	74909   Click image for larger version
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
Old 02-01-2009, 08:50 AM   #8
2002 25' Safari
Dewey , Arizona
Images: 62
The tanks look great, much better then the small painted ones that you had. I need to get some more work done with the cyclo today as well. You guys are making me look bad.
Richard
Old 02-01-2009, 08:56 AM   #9
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
WOW!! How did I miss those aluminum tanks on CL? Oh, probably because I already have some. Those look great. Yup, the Cyclo needs to come out of hibernation now that both you and Richard are going to make me look worse. Can't have the dullest shiny trailer at DH3.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 02-01-2009, 09:31 AM   #10
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
Richard,
We are curious to see how it works. We are going to try a random orbit car buffer on the last pass to see how it removes the swirls. Can't wait to try your cyclo at DH. Have fun today and get lots of rags!
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
Old 02-01-2009, 09:33 AM   #11
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
Originally Posted by flyfshr View Post
WOW!! How did I miss those aluminum tanks on CL? Oh, probably because I already have some. Those look great. Yup, the Cyclo needs to come out of hibernation now that both you and Richard are going to make me look worse. Can't have the dullest shiny trailer at DH3. ;;;;;0
FF
No worries Brad, I think you are still good with the shininess.. We still have to complete the second pass.. it is going much faster than the first one thankfully! We are looking forward to seeing you in a couple of weeks.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
Old 02-01-2009, 11:20 AM   #12
2002 25' Safari
Dewey , Arizona
Images: 62
I think I should have done this sooner. I need 2 passes with "C" to get it looking good, sometimes 3 passes. It will be a while before I can get to the "S".
Richard
Old 05-03-2009, 05:37 PM   #13
1973 25' Tradewind
Hendersonville , North Carolina
can someone tell me, roughly, what is the weight savings going from std. 30lb. tanks to the aluminum ones?
gottafly is offline   Reply With Quote
Old 05-03-2009, 05:47 PM   #14
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Yes - check out the table in this article for weights.. Propane Tanks
You should save about 6 lbs per tank.
AirForums Custom Search
Janet H is offline   Reply With Quote
New Aluminum LP Tanks moosetags LP Gas, Piping, Tanks & Regulators 20 08-30-2007 08:57 PM
Need help mounting my new ALUMINUM LP tanks sequoiacoast LP Gas, Piping, Tanks & Regulators 44 03-21-2007 09:28 PM
Securing Aluminum Tanks flyfshr LP Gas, Piping, Tanks & Regulators 15 07-18-2004 01:47 PM
where to buy new aluminum lp tanks.. JohnGalt48 LP Gas, Piping, Tanks & Regulators 3 09-14-2002 10:36 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 01:56 PM
