Does anyone know if it was standard to put steel propane tanks on a 70 model AS? We have a "new" 70 Overlander-well it was built in 69 so technically it's a 69. The tanks have the old original valves that will need to be replaced so I'm considering swapping for new tanks in aluminum because I believe these to be steel that has shown signs of slight rust and have been painted numerous times. Thanks!
2010 30' Classic
South of the river
If you aren't sure of the material the weight will give them away.
Aluminum tanks of 20, 30, and 40 pound capacity have a tare weight of 14, 16, and 21 pounds respectively. It is stamped on the collar after the letters TW and may vary up to a pound or so depending on the vintage and manufacturer of the tank.
The steel ones have a tare weight of 18, 25, and 33 pounds for the same sizes.
If the tank has a float gauge it may weigh a little more.
yes of course a magnet, duh...! Someday my brain will kick in, just hope it's not too late! Thank you for that solid dose of logic. I'm also interested in what was original to figure out if these are original or had been replaced at some point. Thanks for the replies to my thread!
