Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 03-12-2005, 09:55 PM   #1
Aluminum LP gas cylinders
I'm considering mounting 2 aluminum cylinders as I prefer
look of polished aluminum cylinders.
Then I can eliminate that superfluous aluminum box.
Any experience from other members?
reventlow is offline   Reply With Quote
Old 03-12-2005, 11:17 PM   #2
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Do a forum search on "polishing aluminum tanks" and you will see several threads with posts showing pictures of polished tanks. They sure look sharp.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 03-12-2005, 11:48 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Greetings Reventlow!
Welcome to the Forums!
I purchased a pair of 40 pound Worthington Aluminum LP tanks for my Overlander prior to having it polished and Plasticoated at P & S Trailer Service in Helena, OH. Part of the polishing job included polishing the tanks.
If you are a do-it-yourselfer and enjoy dirty work, it isn't particularly difficult to polish the tanks (the area around the valves will require quite a bit of hand work). I have had the opportunity to watch several demonstrations, and one thing that I learned from one demonstration was that a wooden support cradle made the process easier to manage - - the cradle was designed such that the tank was fully supported by the carpet covered wood radle at the top ring and bottom ring - - the cradle held the tanks secure allowing the use of the typical power-tools for polishing. It is one demonstration that I didn't photograph for some reason.
When the Ruths polished my coach, they didn't Plasticoat the tanks as they felt that the Plasticoat would be too easily damaged with the removal and reinstallation maneuvering when the tanks are refilled. Thus far it hasn't be a tremendous problem - - I hand polish the tanks the coat them with Walbernize when the coach is Walbernized (twice yearly).
I have attached a photo of the tanks following their annual Walbernizing about two years ago.
Good luck with your project!
Kevin
ID:	10876   Click image for larger version
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 03-14-2005, 11:44 PM   #4
gotair's Avatar
Send a message via MSN to gotair Send a message via Yahoo to gotair
looks great Kevin,
Dan.
Life's short...take your kid camping
gotair is offline   Reply With Quote
gas valves gmlcjb LP Gas, Piping, Tanks & Regulators 5 07-17-2006 09:31 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Oven gas line broken lbrodsky LP Gas, Piping, Tanks & Regulators 4 07-23-2002 03:52 AM
Squirrel Eating Gas Lines! lbrodsky LP Gas, Piping, Tanks & Regulators 8 07-06-2002 10:03 AM
