Old 10-25-2015, 01:14 PM   #1
2008 22' Safari
Waxahachie , Texas
Airstream Safari 22 08 HELP!!
We have been in the AS for about 4 months now. Still learning a lot and not knowing anything the whole time. We have had a major blow out the first week we had it, it ruined all the piping under the restroom/fridge (*this may be why I am having the problem). Then a storm blew out our back window. So it's been a hell of a time getting adjusted to this full time
My problem is, last night got super cold and the furnace did not kick on at all!! We had used it during the day and it worked fine. The stove is still lighting so we have propane. We have been having trouble with our fridge staying on. The check light has been coming on a lot but for some reason it has been working fine today. I just have no clue what to do or check! HELP US OUT FOLKS
*currently in OKC
FAstream is offline   Reply With Quote
Old 10-25-2015, 02:36 PM   #2
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Did all this happen after the blow out? You may need to get it into a shop.
This guy has a good reputation in Oklahoma City area and works on Airstreams.
Griffith RV Recreational Vehicle Service - Oklahoma City - (405)-495-2590
Kelvin
Old 10-25-2015, 04:25 PM   #3
1974 Argosy 20
Kooskia , Idaho
It sounds to me like your battery voltage is down. Are you plugged into grid power? Is your charger/converter working? Do you have a Use/Store switch and is it properly positioned? Do you have a solar system?
If the refrigerator is erratic, and the furnace too, I think you are running low voltage on the 12 volt side. If you had solar, it might charge enough during the day to operate things, but as soon as the sun goes down, nothing.... Assuming you are not on grid power that is.
If your converter/charger was not operating right, or your use/store switch was set wrong, it could do the same thing, even plugged into grid power.
So, more information is needed.
Old 10-26-2015, 09:40 AM   #4
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
We've had a major blowout too. The tires were 5 years old and yes it was on same side as yours. Seems that side has more weight on the tire. Proper inflation isn't enough if they get old. I agree with the others about the low voltage. You may need a new battery. Good luck.
Ahab is offline   Reply With Quote
Old 10-26-2015, 12:44 PM   #5
c177tx's Avatar
2008 19' Bambi
Images: 20
Might check pressure regulator on propane system. Working in the warm days and have trouble on cold nights. Propane expands and contracts like all gasses regulator is there to keep the pressure constant.
c177tx is offline   Reply With Quote
help, help, help. new to it all. ohwally Member Introductions 5 08-24-2008 04:18 PM
HELP HELP HELP!! Lug nuts & Stems Chitown AirStreamers Wheels, Hubs & Bearings 4 08-18-2008 04:41 PM
Hot Water Heater HELP HELP HELP!!! Igor68 Water Heaters, Filters & Pumps 2 06-22-2006 08:07 PM
Help Help Help!!! rebel beck 1974 - 1979 Sovereign 9 01-07-2006 03:00 PM
