Old 03-02-2009, 09:34 AM   #1
Advise for updating/replacement LP Line and Regulator
I replaced my refrigerator with the same brand and same size on my 1975 Argosy 20ft MH and want to also replace my Lp gas line and regulator. What size do I need and where would you recommend to purchase. Camping just around the corner! Thanks
911rs is offline   Reply With Quote
Old 03-02-2009, 10:00 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you are replacing the gas line you will most likely replace it with soft copper. If so you will need a flaring tool to make the flares on the pipe. Depending on how many things will be on the gas line. If you are supplying a heater, ref., and stove you should run a 1/2 in. line from the hose coming off the regulator and branch off with 3/8 in. to each item.
You can buy the copper and tool at any Big Box store or plumbing supply dealer.
I would check with a propane supply house for the regulator for reasons of cost. If not there any RV dealer will have it.
2004 Excursion 4x4
Replacing main LPG line from regulator Safari64 LP Gas, Piping, Tanks & Regulators 3 02-17-2008 11:05 PM
Updating our '73 Excella 500 Vinoblanco General Interior Topics 2 03-15-2006 11:21 AM
main LP supply line from regulator Byron71 LP Gas, Piping, Tanks & Regulators 6 11-15-2005 12:08 PM
Updating Tanks (hopefully) Bobolo Waste Systems, Tanks & Totes 1 03-16-2005 08:22 PM
Updating Electrical Goodies... JeepinAudiophile Electrical - Systems, Generators, Batteries & Solar 43 03-04-2005 05:27 PM
