Old 10-11-2005, 08:48 PM   #1
1989 34' Limited
southern , ontario
Adding a barbeque addapter to existing copper lines
I am trying to find a brass coupling, at one end there should be a male fitting for the flex able hose coming frome the LP gas regulator, the other end should have a female end to attach to the 1/2" copper pipe, and in the middle of this coupling there should be a female thread to screw in the LP gas flexable hose attachment fitting.
I have gone to a couple of RV stores, and have seen a coupling with a very restrictive hole of about 1/4" , where as the copper pipe I BELIEVE is 1/2".
any help would be appreciated
letsgo is offline   Reply With Quote
Old 10-12-2005, 12:52 PM   #2
Bradjun1's Avatar
1999 34' Limited
1962 19' Globetrotter
Northern , Minnesota
Go to a good hardware store. They should be able to help you.
Bradjun1 is offline   Reply With Quote
Old 10-12-2005, 09:51 PM   #3
1989 34' Limited
southern , ontario
I have tried the hardware stores no luck thats why I'm posting here.
thanks
Old 10-12-2005, 11:02 PM   #4
azflycaster's Avatar
1975 25' Tradewind
Dewey , Arizona
Images: 62
Instead of connecting after the regulator (low pressure), why not connect between the regulator and the tank (high pressure). Whatever you are connecting to should have a regulator attached to it. This setup is from CW and comes with a 12' hose.
http://www.campingworld.com/browse/s...4&skunum=24017
The hose can be removed from the line when not in use.
Richard
Copper vs. PEX ckeysor Fresh Water Systems 19 07-11-2007 01:03 PM
new water lines Rob Fresh Water Systems 29 07-11-2006 09:25 PM
Copper Canyon (Barranca del Cobre) Pahaska On The Road... 0 07-25-2002 08:14 PM
Exterior gas LP lines 83Excella LP Gas, Piping, Tanks & Regulators 1 05-23-2002 02:06 PM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 07:04 AM
