Old 10-03-2016, 04:47 PM   #1
ericpeltier's Avatar
Superior , Colorado
add a port to a fiberglass tank
Hello, all!
I need to add an inlet to a fiberglass waste tank that fits in my 1972 Streamline. Does anyone have experience with this? The big issue....I do not have access to the inside of the tank (shape is too convoluted). All work needs to be done on the outside of the tank. Impossible? Thanks!
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
ericpeltier is offline   Reply With Quote
Old 10-03-2016, 08:01 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I'm surprised it is a fiberglass tank. But I don't know your vintage trailer at all. If it is fiberglass, I believe you could drill a hole, and "lay up" fiberglass and resin around the fitting you want to add. Kinda like working on a boat.
Airstream waste water tanks are polyethylene plastic, usually rotomolded. This material is thermoplastic, meaning it can be melted and retain its original strength. Factories can "spin weld" fittings to polyethylene tanks. Some folks have heat guns where you can "braze" a fitting to a tank with pretty good success.
And I use rubber grommets because I'm generally lazy and can't spin weld. With this component you get the right size hole saw, deburr the hole you drilled, install the grommet, and then install the fitting you want. These grommets will not work on fiberglass tanks as they are too rough on the outside. The grommet seals on the ID of the drilled hole, and the OD of the installed ABS pipe. Most of my connections were 1 1/2 ABS pipe.
David
Name:	1312 Plumbing New Holding Tanks Grommet Side View.jpg
ID:	272813   Click image for larger version
Name:	1404 Waste Tanks Grommets Installed.jpg
Old 10-03-2016, 08:36 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
When I repaired my 68 Trade Wind, I had to replace the black tank. I ordered a factory replica from Inland RV. Very high quality fiberglass, and expensive. It came with no fittings, I had to cut the hole for the vent stack and the toilet. Fittings were included with the tank and following the instructions I fiberglassed the fitting in. I a used West System epoxy resin instead of polyester and fiberglass cloth. The process was very easy to do. Make sure you rough up the gel coat before you glass in the fittings to give the resin better adhesion.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 10-03-2016, 08:47 PM   #4
65CV's Avatar
Western , Massachusetts
Try the Fastener section here: http://www.westsystem.com/ss/use-guides/
65CV is offline   Reply With Quote
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 09:35 PM
any residents of Sequim ,Port Townsend or Port Angeles kingfisher24 On The Road... 6 10-15-2013 09:57 AM
External port from water tank Jeremy9107 Plumbing - Systems & Fixtures 1 09-27-2012 05:14 PM
Does old fiberglass insulation equal new fiberglass insulation? Petethefeet General Interior Topics 7 11-14-2010 01:16 PM
Fiberglass black tank Wooden Rivet Waste Systems, Tanks & Totes 1 07-31-2010 09:39 PM
