Old 05-17-2014, 11:14 AM   #1
84 International Water Heater
Would an 84 have come with a gas only water heater? I know the water heater that is currently installed is dual fuel but the electric portion is hooked to a washing machine power cord and has been plugged as needed by the previous owner. There are no switches I can find that would have controlled the water heater.
Pat
PatCoates is offline   Reply With Quote
Old 05-17-2014, 08:40 PM   #2
1986 31' Sovereign
Miami , Florida
Aftermarket modification. Not particularly safe if there is no thermostat controlling the heating element. There are legitimate, UL listed electric upgrades for most gas only water heaters that have thermostats and proper wiring but yours sounds like someone's science project.
I wouldn't use it.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 05-17-2014, 08:45 PM   #3
1982 34' Limited
Harrowsmith , Ontario
I have an '82 and it was originally only gas but the PO added a "HotRod" which seems to work well (one of the UL approved types n2916s mentioned). I'm not sure how much life my tank has left in it anyway but when it dies I'll replace it with a factory unit that is electric/gas if I can. You may be in a similar situation from the age of your trailer.
http://www.rvupgradestore.com/v/vspf...es/hottrod.pdf
BradB is offline   Reply With Quote
Propane Heater or Instant water heater valontjej Plumbing - Systems & Fixtures 1 04-09-2012 08:56 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
