Old 09-19-2008, 09:09 PM   #1
2001 19' Bambi
Falmouth , Massachusetts
8-gal gasoline tank in LP tank profile for genset
Has anyone seen or tried this product from Transfer Flow? The link: OEM Fuel Tanks (near bottom of page) shows an 8-gallon gasoline tank to be used as a transfer tank system to a gasoline powered generator on an RV. The website says it complies to NFPA-1192 standard.
The tank is intended to take the place of a standard vertical propane tank and be mounted on a trailer's existing tank holder. It doesn't say what size- 20 or 30lb.
I've requested more information on this from the company and will post what I receive from them.
Maybe this thread should be posted in the forum section for generators?
Marshall Swartz
2001 19-ft Bambi
2013 Honda Ridgeline RTL
mswartz is offline   Reply With Quote
Old 09-19-2008, 09:24 PM   #2
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
I've been to their place in Chico, Ca.
First class place.
That tank is a great idea!!
Only problem I see is that some idiot may try to transfer the gas into a real propane tank.lol ( just thinking about the other thread - transferring propane)
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 09-19-2008, 09:33 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My guess is that they are the same as 30 pound tanks. Be aware that they may not be exactly the same size. There is a height difference between steel and aluminum tanks as well.
It is an interesting concept. In my opinion, a better solution would be to convert your generator to propane and use the existing tanks.
Richard
Old 09-19-2008, 09:45 PM   #4
2001 19' Bambi
Here is a link to their brochure:
http://www.transferflow.com/Resource...tor%20tank.pdf
Marshall Swartz
2001 19-ft Bambi
Old 09-19-2008, 11:54 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Propane tank into gas tank.
Hi, I was thinking the same thing, but I was going to buy a new propane tank and an automotive filler neck and have a professional welder put it together. I like this, but I think it is a little pricey.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-20-2008, 06:12 AM   #6
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
I'm with you BOB! Seems like you could just unscrew the opd valve,modify it to vent,and use a oaklahoma credit card to transfer fuel.There's been times where a few extra gallons for the Burb would be nice.
www.popasmoke.com
YETI ( 65 Quart )
Old 09-20-2008, 06:23 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Tim, put down the gas tank, and step away from the trailer!...
19 Gal Black Tank Upgrade to 39 gal? Old_Town Waste Systems, Tanks & Totes 6 07-17-2007 03:21 PM
$4 per gallon gasoline JimGolden Off Topic Forum 94 05-03-2007 09:49 AM
Gasoline tank replacement? Astrodokk Classic Motorhomes 10 03-18-2007 06:40 PM
Gasoline prices myoung Dollars & Cents 5 02-09-2006 07:47 AM
10 gal in a 6 gal Hole aviontt Water Heaters, Filters & Pumps 18 12-19-2003 06:23 PM
