Old 09-10-2015, 02:33 PM   #1
1968 26' Overlander
Portland , Oregon
68' Overlander: What line from regulator to main supply
I am replacing my ancient regulator (which leaks when I switch tanks) with a new Cavagna automatic two tanker. I am also replacing the rigid pig tails with modern green handled rubber ones. All of which I have on hand. I also would like to replace the semi rigid line from the regulator to the main copper supply trunk line with a modern equivalent.
My question is, what is that line? I thought it might be a domestic appliance gas line (yellow Home Depot type) but that doesn't seem right. I realize there is a simple answer, but I haven't definitively found it on line. Here are photos of the whiteish line I am talking about. Thanks for weighing in!
AirstreamPDX is offline   Reply With Quote
Old 09-11-2016, 08:40 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Ummmm... that looks a lot more like a water heater connecting line that the previous owner jerry-rigged. It is, in my ever-so-humble but occasionally correct opinion, very UNSAFE!
I'd do some more research on getting the correct propane-rated line. Your propane distributor is the best place to start.
Seriously, they'll custom-make a hose for you.
Old 09-12-2016, 07:27 AM   #3
1974 27' Overlander
Baltimore , Maryland
This is what you're looking for:
1974 Overlander In Progress
TheGreatleys is offline   Reply With Quote
LP supply line uwe LP Gas, Piping, Tanks & Regulators 9 06-17-2009 02:49 PM
Replacing main LPG line from regulator Safari64 LP Gas, Piping, Tanks & Regulators 3 02-17-2008 11:05 PM
main LP supply line from regulator Byron71 LP Gas, Piping, Tanks & Regulators 6 11-15-2005 12:08 PM
Propane Supply Line? Over59 LP Gas, Piping, Tanks & Regulators 14 02-16-2005 06:50 PM
New LP Supply line? themostbob LP Gas, Piping, Tanks & Regulators 0 05-01-2003 09:35 AM
