Old 12-21-2005, 06:34 AM   #1
1965 26' Overlander
Acworth , Georgia
65 Overlander Propane tanks
Do we need to replace tank valves from this unit before refilling? This will be my first time with it. Not sure if there are code issues.
PhilMateo is offline   Reply With Quote
Old 12-21-2005, 07:17 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The easy way to tell if the tank has been upgraded is to look at the knob on the valve. The converted tanks will have a triangle shaped knob while the non-upgraded will have a round knob.
Richard
Old 12-21-2005, 07:26 AM   #3
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
When you go to have the tank filled they will tell you!
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 12-21-2005, 08:08 AM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
If you have steel tanks and would like to change to the aluminum tanks, it might be a good time to do that. If you have aluminum tanks and just want new valves, go to the largest gas supplier in the area. They may have the right valves in stock. Many smaller dealers have mistakenly replaced the valves with the valves intended for steel tanks which they have in stock. There are special valves for aluminum tanks, which smaller dealers do not stock.
Old 12-23-2005, 04:13 PM   #5
1965 26' Overlander
Acworth , Georgia
Another question
Is there a requirement for inspection of the tanks?
Old 12-23-2005, 05:58 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
For steel tanks, they need to be re-certified after 12 years from the original date of manufacture, and every 6 years thereafter. I am not sure about aluminum tanks, I have heard they do not need recertification, but I have not verified this.
Old 12-25-2005, 07:42 PM   #7
Hippo's Avatar
Battle Ground , Washington
To save your old tanks you can buy the new valves install them and then have the tanks inspected. It cost me about $35.00 for the valves and 25.00 for the inspection.
Hippo is offline   Reply With Quote
Old 12-25-2005, 08:23 PM   #8
2002 25' Safari
Dewey , Arizona
Images: 62
That's $60 for both tanks, not each?
Richard
Propane injection Rik Mechanics Corner - Engines, Transmission & More... 13 09-23-2003 10:34 AM
propane tanks david h Our Community 5 01-12-2003 07:49 PM
Retrofitting Old Propane Tanks (non-opd) leslie LP Gas, Piping, Tanks & Regulators 18 09-20-2002 10:24 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
