Join Airstream Forums Today
Old 03-27-2005, 04:49 PM   #1
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
65 Caravel - Replace Hydo Flame
I think my Hydro Flame in my 65 Caravel is shot. A large amount of rust coming out the bottum of the unit. What can I replace this unit with, in the same place that the Hydro uses under the Stove / Oven?
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
robandzoe is offline   Reply With Quote
Old 03-27-2005, 05:23 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Since showing my ignorance seldom slows me down, what is a "Hydro Flame"?
Tom
1967 Airstream Overlander International
AL-1
Old 03-27-2005, 05:53 PM   #3
robandzoe's Avatar
Plymouth , New York
My Hydro
In the 65 Caravel, the furnace is called a Hydro Flame. It is a propane - no electric, furnace. It fits under the Stove and Oven. Not too sure how it operates.
Rob
Plymouth, NY 13832
Courtesy parking
Old 03-27-2005, 06:22 PM   #4
TomW's Avatar
1967 26' Overlander
Thanks!
Although I can't necessarily help you with the problem, would you happen to have a picture of the device? It sounds like a catalytic heater. "Sounds like it" because all of the catalytic heaters I have seen up to this point have been mounted on the side of a base cabinet expanse.
Not to badger you with questions, but does a '65 Airstream have any ducted heat to keep the black tank warm?
Tom
AL-1
Old 03-27-2005, 07:02 PM   #5
robandzoe's Avatar
Plymouth , New York
Not a Catalytic
Here is a picture of it. It exhausts through the side of the trailer.
Rob
Plymouth, NY 13832
Courtesy parking
Old 03-27-2005, 07:37 PM   #6
Over59's Avatar
Putnam , Connecticut
Images: 37
We are in the same boat. Nothing fits well in that area. You could get a cat heater but it is awful close to the side bed when pulled out. You will find some discussion on this thread. http://www.airforums.com/forum...ad.php?t=14679
I'm still waiting for the final results. It's a problem. We use a small electric heater when we have hookups. A Cat by the door on the end of the counter is another way to go.
Over59 is offline   Reply With Quote
Old 01-06-2012, 05:52 PM   #7
1967 17' Caravel
whitmore lake , Michigan
Found a user manual for the hydro Flame if it helps.
I was looking for the manual to read before trying to fire the furnace in my 67 Caravel for the first time. This may not be for the exact one that is in our campers, but it seems to be relevant in start-up procedure and troubleshooting. If you want the doc file that was too large to attach just email me and i will shoot it over to you. If you do decide to get rid of the Hydro Flame I would be interested in yours for parts. Let me know a price if you want to get rid of it. (your cover looks nicer than mine). If mine does not work I was considering just putting a small electric heater behind the Hydro cover to keep the look going.
Ruggedjeep3 is offline   Reply With Quote
Old 01-07-2012, 06:12 AM   #8
Plonk
, , Minnesota
Hi RuggedJeep. Welcome to the forums. Since this is an older thread (check the dates) you may not get a reply from the original posters.
The Atwood Everest heaters are probably the best replacement available today. I believe they have come on the market since the opening post. The sizes are similar although some slight modifications to the exterior wall would be required since the exhaust has been replaced with a combined air inlet/exhaust port.
Old 01-07-2012, 07:20 AM   #9
1967 17' Caravel
Thanks Jammer
So... I am the fourth owner of my Caravel and I was told by the last owner that the heater did not work and has not worked in 20 years or so. I'm glad I downloaded the manual. It works GREAT! Best of all it has not been used much because the previous two owners did not know how to light it. Thanks for the heads up on the date of thread and the tip on the new heater should I ever need one. Now on to the fridge that is supposed to have had the ammonia leak out of it. What are the chances of that working too? Fingers crossed!
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
another caravel owner davidw 1966-68 Caravel 46 02-03-2005 06:53 PM
Restoration of our Airstreamer Caravel Hagen 1965 Caravel 2 11-10-2002 02:15 AM
'71 Airstream Caravel 18' weight specs PeterH-79MH 1969-1971 Caravel 0 06-15-2002 06:28 AM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 07:55 PM
