Old 10-19-2007, 12:36 PM   #15
1968 26' Overlander
Ann Arbor , Michigan
Images: 11
Where can I get the valves changed. I have a LP company close to me...would that be O.K..or...is this something that I can do myself?
Aluminati is offline   Reply With Quote
Old 10-19-2007, 12:54 PM   #16
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I would have it done, only costs a few bucks and they have the tools. Make sure you get the correct valve. The one for an aluminum tank is different then a steel tank (I think).
Richard
Old 10-21-2007, 02:45 AM   #17
1972 25' Tradewind
Madison , Wisconsin
Try a service cooperative
When I had mine done I went to a local cooperative. They had the special wrench (I tried to get the valve out with a buddy & we bent a 1 inch iron pipe like it was a pretzel). They only charged me for the refill, as I already had the valves.
Contact some of the larger coops that also do heating work, you will find someone that will change the valves & cert the tank for you. A few phone calls should do it.
In my area it was a former CENEX that had just left the franchise.
Smokin Camel is offline   Reply With Quote
Old 02-10-2008, 09:47 PM   #18
azfiredog300's Avatar
Surprise , Arizona
Hey Richard, I am starting my polish job tomorrow, any tricks I can use? Did you sand them or compound?
azfiredog300 is offline   Reply With Quote
Old 02-10-2008, 09:55 PM   #19
soldiermedic's Avatar
Florissant , USA
I have dual 40# tanks on my Ambassador, but I am looking for 30# tanks. If anyone would like to upgrade from 30# to 40# tanks PM me.
By the way Melody, Shari, Richard...that is fantastic work!
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 02-10-2008, 10:05 PM   #20
2002 25' Safari
Dewey , Arizona
Images: 62
Mine were new and needed a little sanding especially where it had some weld splatter. I used very fine #400 & #600 wet paper. I then used a liquid polish from Lowe's that is used to shine up PU truck tool boxes called Truck Box polish. I also bought a bunch of work towels at Costco to polish with. You are going to use a bunch of towels. All of oxidation will come off black.
One thing that helped me was I built a stand out of scrap wood and some carpet and clamped it to a work bench. I think this made it a lot easier.
Gracie in the picture was no help at all, but she is cute...
ID:	54122   Click image for larger version
Richard
Old 02-10-2008, 10:13 PM   #21
Surprise , Arizona
Very nice work. I bought 500, 1000 and 1200 grit wet/dry so I will start with that. Also, I am going to the restoration rally and was wondering if I could hook up with you or Brad prior for a check because this will be my first trip ever as an adult. My A/S is at 14th st and Dunlap, would you or Brad be closer?
Old 02-10-2008, 10:26 PM   #22
2002 25' Safari
Dewey , Arizona
Images: 62
We are about the same distance. I am at Central and Union Hills and Brad is near Greenway and 40th Ave. We can set something up next week after the Dead Horse Rally and Brad gets back from Hawaii.
I thought you were in Surprise???
Richard
Old 02-10-2008, 10:38 PM   #23
Surprise , Arizona
I am, but my inlaws are in Sunnyslope where I grew up and that is where I have to keep it due to HOA. I have to wait till my axles come in, should be in about 2 more week.
Old 02-11-2008, 08:05 AM   #24
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Recertification
Nobody in NM has ever mentioned a need to have my tanks "recertified". Could this be a state reg that varies from state to state?
Old 02-11-2008, 08:42 AM   #25
2002 25' Safari
Dewey , Arizona
Images: 62
Tank inspection is a Federal Mandate. Here is a brief description of how it works.
Cylinders are subject to recertification (also known as requalification) twelve years from their date of manufacture and every five years after that. For example, a cylinder manufactured in January of 2000 will have to be recertified in January of 2012 meaning if you take your bottle to the propane company in April of 2012 to be refilled, it will have to be requalified by authorized personnel before it can be filled. The recertification process is simple and does not take too long to complete. Think of cylinder recertification as an inspection similar to that of your car. A vehicle has to be inspected annually so that it may continue to operate safely on the road. Similarly, a propane cylinder must be inspected so that it may continue to operate safely in LP Gas service.
Richard
Old 02-11-2008, 08:42 AM   #26
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Nope, Federal since we all drive on Interstate Highways.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 02-11-2008, 09:49 AM   #27
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Might as well be. In truth, the recommendations are written by the National Fire Protection Assocation, which puts out a manual covering all aspects of propane safety. The latest version is NFPA 58, with the next major revicion cycle scheduled for 2010. (This is not casual reading material!) The various states generally accept all or most parts of whatever the NFPA recommends, subject to their own revisions, additional recommendations, and so forth. In general, though, if it's in the NFPA manual, it's national, including especially the parts about recertification of and OPDs on DOT cylinders (e.g., the vertical bottles on RVs, barbeques, and the like).
Lynn
WBCCI 21043
Old 02-11-2008, 12:51 PM   #28
Lumatic's Avatar
1993 34' Excella
Images: 16
recertification
I have had 3 or 4 70s vintage tanks changed to OPD valves. Maybe they were recertified as a matter of course. Never had anybody balk at refilling. Are recertified tanks restamped? How can I tell if they are recertified?
Is there an sister agency of the mattress tag police lying in wait for me?
Do i need tanks? rama777 Waste Systems, Tanks & Totes 1 10-01-2006 03:04 PM
Where to get new tanks? JimGolden Waste Systems, Tanks & Totes 7 03-15-2006 07:52 PM
LP Tanks ga501 LP Gas, Piping, Tanks & Regulators 6 09-08-2005 07:48 PM
Tanks Over59 Waste Systems, Tanks & Totes 3 03-25-2005 06:29 PM
Need new LP tanks Bob912 LP Gas, Piping, Tanks & Regulators 7 05-26-2004 03:43 PM
