Old 08-05-2015, 10:39 AM   #1
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
30 lb to 40 lb propane tanks - Question
When I bought my 99 Excella it had one aluminum and one steel propane tank, both 30 lb. Since they were different heights the tie down would not work properly. Last year I ran across 2 used 40 lb aluminum tanks so I purchased and installed them. The only thing I did was to extend the tie down rod. The rubber hose that runs between the regulator and the copper tubing was a stretch, but it worked.
This year I noticed the pigtails are starting to get stiff with age and starting to show some deterioration. They have a tag showing date of manufacture was 1999. I assume the regulator is original also. I've decided it is time to replace the 16 year old regulator and flexible hose.
My questions are regarding the 1/2" flexible hose between the regulator and the copper pipe. The original hose on the trailer is ~36" long, the one that came with the 30 lb tanks. It seems to be in tension now, maybe too much. If the trailer would have originally had 40 lb tanks, what length would this hose have been? Should I install a longer one? Anybody have a part number? (there is none for 40 lb tanks in my manual for this year)
Thanks for any suggestions!
Alan
Old 08-05-2015, 10:43 AM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I have original Worthington #40 aluminum tanks. My regulator is situated at the bottom of the tanks. My pigtails are 36".
Any hose shop will re make the pigtails reusing the ACME nut and other fittings. Should cost you $15-20 tops!
Also search for my recent post regarding non calibrated but brand new regulators!
Old 08-05-2015, 10:46 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by A W Warn View Post
My questions are regarding the 1/2" flexible hose between the regulator and the copper pipe. The original hose on the trailer is ~36" long, the one that came with the 30 lb tanks. It seems to be in tension, maybe too much. If the trailer would have originally had 40 lb tanks, what length would this hose have been? Should I install a longer one? Anybody have a part number? (there is none in my manual for this year)
You don't want too much line. But if 36" almost worked, then 48" seems like a reasonable length, leaving you a bit of slack.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-05-2015, 10:55 AM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I had not thought of mounting the regulator lower and using longer pigtails.
That might work.
Already read your post. I will be measuring the water column with the appliances operating. Thanks!
Alan
Old 08-05-2015, 11:02 AM   #5
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Keep in mind, the lines are high pressure lines, so they need the inner liner, if you're having them made, have ptfe sealant smeared on the ends to seal them. Also renew the bigger flex live between the regulator and hard copper line. I think the oil causes a delamination.
I just assumed all regulators were at the bottom of the tanks!
Good luck!
Old 08-05-2015, 11:10 AM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Good luck!
Yeah, do not use the "tape" alone. I use the yellow tape and smear with the paste for "gas" plumbing.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-05-2015, 11:13 AM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Good luck!
Both of my trailers have propane bottle covers. The regulator in them are mounted high, I assume, to allow for access to the automatic change over valve. After more thought, I would like to keep the regulator in the original position.
I think the suggestion to get a custom made hose would be better, unless someone who has 40 lb tanks on a trailer similar to mine comes through with a measurement or part number.
Alan
Old 08-05-2015, 11:16 AM   #8
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
CWF,
We have the same trailer. Do you have the original 30 lb tanks?
Alan
Old 08-05-2015, 12:37 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
CWF,
Yes! 30# aluminum with remote electric "gauges".
I replaced the valves and recertified last year. Bought one additional with gauge last year, too.
Channing
WBCCI# 30676
Old 08-05-2015, 01:38 PM   #10
Mission , Texas
My 75 Overlander has 40# tanks, not original. From the bottom of the regulator is a 6" pipe nipple, the bottom hose is connected from that to the soft copper that runs under the belly (on the outside). The all-thread on the clamp has an extention. The individual tanks have two pins each to use at the botttom to help hold them in the rack.
When we got it, the pig tails were stiff, and the bottom hose slightly stiff. I mounted the regulator to the clamp down bracket facing forward and added elbows to the gas inlets to reduce stress on the pig tails. Then ordered pigtails of the appropriate length, in this case 12". For the hose from regulator to soft copper, 3/8 MPT on one end and 5/8 Flare on the other, 24 inches long, I could only find an identical hose, nothing longer, so the pipe nipple stayed.
Next for gas is a tank cover.
nrgtrakr is offline   Reply With Quote
Old 08-05-2015, 01:47 PM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Here is pic of the stamped collar:
Channing
WBCCI# 30676
Old 08-05-2015, 03:08 PM   #12
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
My trailer originally had the gauges with sensors like those shown in your photo, but no longer.
Alan
Old 08-06-2015, 11:03 AM   #13
1977 31' Sovereign
Lynnwood , Washington
Why not fabricate an extension with copper tubing??.....something you can install on either end of the hose.
Tom
TomKirk is offline   Reply With Quote
Old 08-06-2015, 11:07 AM   #14
2000 25' Excella
fallbrook , California
Watch out for pressure vessel certification on older tanks, can run out of date
bruceganoe is offline   Reply With Quote
'Convert' from 30# tanks to 40# tanks HeavyAssault LP Gas, Piping, Tanks & Regulators 19 11-28-2013 11:42 AM
*Newbie Indoor Storage Question #2: How do I disconnect propane tanks on 2009 Bambi? TikiTime Winterizing, Storage, Carports & Covers 3 10-24-2013 08:49 AM
LP Gas Tanks: Replacing 20# with 30# tanks? Pete Vermont LP Gas, Piping, Tanks & Regulators 28 01-30-2008 08:34 AM
Propane tanks storage question GoNomad Winterizing, Storage, Carports & Covers 2 08-27-2006 09:50 PM
Propane tanks question Swingking LP Gas, Piping, Tanks & Regulators 8 10-22-2003 09:55 PM
