Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 10-22-2009, 06:10 AM   #1
Smoky's Avatar
Profile:  Eau Claire , Wisconsin
Question 1/4" inverted male flare adapter?
I bought a Mr. Heater Propane auto changeover two-stage regulator the other day. When I got it home I was surprised that my ¼” pigtails would not fit. The box says the inlets are 1/4" inverted female flare inlets. So is this some kind of marketing scheme to get me to buy special Mr. Heater pigtails? I assume I can buy two 1/4" inverted male flare adapters, but I have had no luck locating them at my local hardware stores. Any suggestions as to where I might find them?...or am I stuck having to buy two Mr. Heater pigtails.
Thanks for any tips.
1961 Avion T-27
Exotic Incense
Smoky is offline   Reply With Quote
Old 10-22-2009, 07:48 AM   #2
Silverhobby's Avatar
Profile:  1956 26' Cruiser/Overlander
1957 26' Overlander
1962 22' Flying Cloud
Vale , North Carolina
Go to the Mr. Heater website and see if you can find what you need there.
Mr. Heater - America's Most Popular Portable Heaters
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 10-22-2009, 07:56 AM   #3
Profile:  1984 31' Excella
Norfolk , Virginia
Images: 11
Gas Connections
Keep in mind that flamable (yea I know its mispelled) gas connections are left handed. Is that the problem? If it is contact a local bottle gas company to see if they have the adapters you need.
Beginner
Beginner is offline   Reply With Quote
Old 10-27-2009, 03:29 PM   #4
Smoky's Avatar
I ordered Mr. Heater Propane Fitting F273729 1/4" Male pipe thread X 1/4" Inverted Female Flare. It arrived today however the male end is too big to fit into 1/4" inverted female flare inlets and the female side isn't big enough to screw in my pigtails. So at this point I am questioning my sanity...I mean how complex can this be, even after about six hours of intense research on the internet and visiting about 6 hardware stores and talking to five people I am still back where I started. What am I missing? Could this be a manufacturing defect?.....or is this simply a defect of my mind.
1961 Avion T-27
Exotic Incense
Old 10-27-2009, 04:59 PM   #5
Kevin245's Avatar
Profile:  1976 31' Sovereign
Rock Hill , South Carolina
Hey Smoky,
Standard flare fittings for gas use are typically JIC - 37 degree, or SAE - 45 degree. I'm not sure if what you have is a proprietary fitting, or a pipe vs. tubing issue. Most of the Big Square Box home improvement stores carry limited inventroy when it come to plumbing fittings. Have you tried a plumbing supply house, or maybe even McMaster-Carr?
www.mcmaster.com
If your not sure about what you see in their on-line catalog you can call their customer service line. They have been very helpful to us. I recently had to order some 4,000 psi JIC fitted hoses for a project, and they walked me right through the inventory with hoses, fittings, adapters, etc...
Does this look like what you need?
Experience can be a difficult teacher...You usually get the lesson first...And the instruction afterwards...
Old 10-27-2009, 09:44 PM   #6
Smoky's Avatar
Thanks for the reply...yes that looks like what I need.
This is the regulator I have.
MR HEATER F273766 REGULATOR 2STAGE PRPNE
Here are the fittings I ordered online.
Perhaps I ordered the wrong adapter?
I'm starting to think I don't have the right pigtails....The ones I have will fit into a single type regulator but I've never had a dual one. Do they make special pigtails for dual regulators?
1961 Avion T-27
Exotic Incense
flare nut split goransons LP Gas, Piping, Tanks & Regulators 12 03-17-2008 08:28 PM
7 Pin Male Trailer Connector. firedog Electrical - Systems, Generators, Batteries & Solar 0 07-31-2007 03:02 PM
hot water heater flare up!!! glacierrunne Water Heaters, Filters & Pumps 5 06-05-2006 10:50 PM
How to flare tubing... Buttercup LP Gas, Piping, Tanks & Regulators 15 07-27-2005 08:51 PM
When Tempers flare "Camper" is there!! airstreamcaravel Our Community 3 07-28-2003 06:48 PM
