Old 08-16-2015, 05:31 PM   #1
2009 22' Interstate
Chetek , Wisconsin
09 Airstream Sprinter Water Heater
water heater s leaking so in the next couple days I will need to pull from the outside and open the Styrofoam box where I think the leak is. Does anyone have a tip or two for this process? Fixable ? Brand? Size?
Wisconsinden is offline   Reply With Quote
Old 08-16-2015, 09:36 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
As far as I know, every Interstate comes with a 6-gallon Atwood dual electric/propane water heater with piezoelectric ignition. Don't recall the model number, but I think this is itů
http://www.amazon.com/Atwood-GC6AA-1.../dp/B00FA4C4ZK
Be careful when buying. Atwood makes similar 6-gallon units in LP-only, and with pilot lights instead of piezoelectric. If you already have LP-only and/or pilot light ignition, you can either replace with an identical unit or upgrade to LP/electric.
Don't know exactly how you would go about removing it, but since they put it in without breaking the styrofoam you should be able to take it out without breaking the styrofoam as well. Look on the back of the heater for water line connections, AND look from underneath the van for floor penetrations for propane and/or water connections before you start trying to remove the unit.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
INTERSTATE SPRINTER- Propane Gas Heater Issue TexasJudge Sprinter and B-van Forum 12 06-27-2014 06:34 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Site for Sprinter & Sprinter-based RV Enthusiasts Zach Woods Sprinter and B-van Forum 0 09-25-2006 04:08 AM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
