07-01-2002, 05:59 PM
#21
418
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley
How about number 6364??
Hope it's no bother......
Uwe
07-01-2002, 06:42 PM
#22
Contributing Member
Austin (Hays County)
Got my number
I have my desired number reserved ... 9632, my date of birth. I may be getting old and forgetful, but I can remember that number.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
07-01-2002, 08:01 PM
#23
1983 27' Excella
Airstreamville
, Kansas
6364
#6364 is in use but you may want to double check when you apply.
John
07-02-2002, 11:51 AM
#24
Got time to look up another?
Hello, the number on my newly acquired A/S is 28827. Not only am I interested in finding out if the number is still available but if someone has an old directory I would love to try and trace back its ownership and learn some of its history.
07-02-2002, 07:47 PM
#25
1983 27' Excella
Airstreamville
, Kansas
28827
#28827 is not in use. Recheck with wbcci when you apply to ensure its still available.
John
07-09-2002, 08:45 AM
#26
WBCCI #''s
Hey,
It looks like my airstream had several numbers plus 4 stars. What do the stars mean?
Also if you wouldn't mind looking up any of these number combinations, that would be great. We are going to sign up to the WBCCI soon.
Thanks- Sharon Lee
16539 12539 16810 16510
07-09-2002, 09:01 AM
#27
Just a member
1978 28' Argosy 28
Lutz
I don't have my book here but I am sure someone can check the numbers for you. You could also call the WBCCI office and they will tell you if it is available as well as put a hold on the number until they get your app. As to the stars, each star signifies 5 continuous years of membership in WBCCI. If your trailer had 4 stars that means a 20+ year member owned it!
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
07-09-2002, 10:59 AM
#28
1983 27' Excella
Airstreamville
, Kansas
Sharon's numbers
Sharon,
None of the numbers you provided are in use*.
* Subject to change per WBCCI.
John
07-09-2002, 11:43 AM
#29
Thanks for looking up the numbers.
I just submitted my application.
I would love to find out more about the first owner. It's pretty cool to know someone really had fun in it! I'ts hard to tell which one of the set of numbers were the ones that were used, they are really faded.
Sharon Lee
07-09-2002, 07:17 PM
#30
Guest
Is 3003 free?
--andrea
07-09-2002, 09:16 PM
#31
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
Andrea ~
Per the 2002 Membership Directory, 3003 is not currently assigned...check with the WBCCI Office to verify it though.
Shari
07-23-2002, 08:29 AM
#32
wbcci#'s
anything on 14120 , i understand he is no longer living...also that he worked for airstream ,had something to do with running gear.... with six stars i would say he had to be around about 30 plus years....
TOM BOONE 1987 SOVEREIGN 25' WBCCI#14120
07-23-2002, 10:16 AM
#33
1983 27' Excella
Airstreamville
, Kansas
#14120
#14120 is not assigned but check with WBCCI to verify.
John
07-23-2002, 05:57 PM
#34
Contributing Member
Got my number!
I requested and received #9632. This is my date of birth (9/6/32).
WBCCI sent me a set of loose numbers, but I was not at all happy with the alignment and spacing I was able to achieve. I ripped the numbers off and ordered a set of vinyl numbers "96329632" which come pre-spaced on a backing sheet. I'll cut the sheet in half and use the straight edge of the sheet to align with the Airstream name. I should get a nice, neat alignment that way.
I ordered the numbers from the same place that made my "Sabre-D" lettering. Kind of pricy, but I think crooked numbers look like heck.
John W. Irwin
WBCCI #9632
07-23-2002, 08:57 PM
#35
1983 27' Excella
Airstreamville
, Kansas
Installing WBCCI numbers
I used 2 inch masking tape to center & keep my numbers straight, ran a length along the bottom using the AS letters as a guide, attached the first number, ran a line of tape vertical along the right side to keep square, attached second number, etc... worked great and looks good. They should include that in the instructions but they dont. If you need to remove them use a clothes iron set on warm and a towl to loosen them.
John
