Old 05-15-2016, 10:31 AM   #897
Jimbcole's Avatar
1958 17' Pacer
Tryon , North Carolina
Originally Posted by FCStreamer View Post
Hi there, is there any record of #4850?
Thanks!
1966 Directory and 1976 Directory
Earl and Georgia Dunn from Genoa, Ohio
Jimbcole is offline   Reply With Quote
Old 05-15-2016, 12:18 PM   #898
FCStreamer's Avatar
2014 30' Flying Cloud
Outstanding. Thank you!
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 05-25-2016, 03:54 PM   #899
Thiss's Avatar
1971 27' Overlander
Monmouth , Oregon
Hi all,
Can anyone tell me more about big red number 8815?
Thanks!
1971 Overlander Twin bed, rear bath.
2016 Ram 3500 Cummins 4x4 Crew Longbed
Thiss is offline   Reply With Quote
Old 05-28-2016, 08:43 PM   #900
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Originally Posted by Waltonfive View Post
Looking for any information on WBCCI #23759
It is on a 28' foot 1967 International ambassator made in Ohio.
Thanks in advance,
Sherry Walton
Hi Sherry,
Finally have time to do the research. WBCCI #23759 was first assigned in 1970, a few years after your 1967 Ambassador was built (and thus first showing up in the 1971 WBCCI Membership Directory). That said, I can only find one couple to which #23579 was ever assigned in the WBCCI Membership Directories over the years (though I only spot checked a few directories after 1985 or so):
1971-1979: Richard & Katherine Willette, Kansas City, MO, no caravans.
1980+: Unassigned.
It thus seems pretty likely that the Willette's owned your 1967 Ambassador in the 1970's. Make some memories of your own in it!
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 05-28-2016, 09:17 PM   #901
1962 22' Safari
2016 30' Classic
Images: 41
Originally Posted by MarkR View Post
Hi, I have a 1960 Ohio Built Tradewind.
The VIN is 240301T
The Original Owner's name (on the Warranty Card) was S. B. Torrence from Sandusky, OH.
The Ghost "WBBCI" Number is: 866
Do your files concur? Or give any additional info . . . or additional History?
Thanks!
MarkR
Hi Mark,
Thanks for your patience. I can't tell much from the VIN except to confirm your trailer is a 1960 Tradewind Twin built in Ohio.
The WBCCI #866 is a low number that should have been first assigned in 1957, obviously before your Tradewind was built, although it does not show up in a Directory until 1958. This number has been reserved for special purposes since about 1970, so it was not reassigned after that year, but the then current members could keep it as long as they remained in the club. Here is how #866 has been assigned in the WBCCI Membership Directories over the years:
1958-65: Arthur R. & Pearl M. Kemp, Dayton, OH, no caravans.
1966-86: Howard & Isabelle Putnam, Alger, OH (1966) nd Kenton, OH (1986), no caravans. They appear to move from Alger to Kenton some time in the 1970's but I did not narrow down the exact year.
1987+: Unassigned.
Also, there was no S.B. Torrence listed in any WBCCI Membership Directory in 1960 or the few years afterward that I checked.
So, what can we tell from this information?
First, The original owner did not join the club.
Second, we can tell that either or both of the Kemps and Putnams owned your 1960 Tradewind since they are the only two couples to have been assigned #866, but we cannot tell for sure which one(s). However, since the original owners and both of the Kemps and Putnams are from Ohio, it is possible all three owned your Tradewind.
Third, the Kemps joined the club before your Tradewind was built, so they would have had to trade up from an earlier Airstream to your 1960 Tradewind at some point, which again seems possible because both they and the original owner were from Ohio.
Fourth, it is likely the Kemps sold an Airstream to the Putnams, because they are both from Ohio and because there was no unassigned year in between the assignments, which generally means the Kemps released their number for reuse because they had no intention of renewing their membership. Most often this occurs when an Airstream is sold. They might have still owned your Tradwind at this time, or they could have upgraded to another Airstream after your Tradwind, we have no way of knowing, but this does raise the possibility that the Kemps sold your Tradewind to the Putnams.
Fifth, it remains possible that the Kemps never owned your Tradewind, but the Putnams did. While possible, this seems less likely than your Tradewind passing down from Torrence to Kemp to Putnam.
Well, that's about all I can tell. Enjoy that Tradewind!
Joe
WBCCI/VAC #6768
Old 05-28-2016, 09:23 PM   #902
1962 22' Safari
2016 30' Classic
Images: 41
Thanks!
#4850 was first assigned in 1961 and may have been assigned multiple times over the years. Due to the research time involved, I will only look it up if information is provided about the year of Airstream it is found on. For example, it this number is on a 1970's Airstream, there is little reason to take the time to research to whom it may have been assigned in the 1960s. I hope you understand.
Joe
WBCCI/VAC #6768
Old 05-28-2016, 09:28 PM   #903
1962 22' Safari
2016 30' Classic
Images: 41
Originally Posted by Thiss View Post
Hi all,
Thanks!
Similar to my last comment, I would be happy to look up the Membership Directory information if you confirm the year of the Airstream that this number is on. I don't want to assume it is on your 1971 Overlander, because #8815 was first assigned in 1963, long before it was built. Checking old Membership Directories is time consuming, so I wish to make sure I am as efficient as possible when doing lookups. I hope you understand.
Joe
WBCCI/VAC #6768
Old 05-29-2016, 10:39 AM   #904
Thiss's Avatar
1971 27' Overlander
Monmouth , Oregon
Joe,
Sorry for being rude. I didn't read earlier posts with your research info requests. Yes, the number is on my 71 Overlander and the unit was originally owned by folks from Minnesota.
Old 05-30-2016, 07:34 PM   #905
1985 32.5' Airstream 325
Calgary , Alberta
Hi Joe,
Do you show anything for 15901? A 1985 325 Motorhome.
jimbro is offline   Reply With Quote
Old 06-06-2016, 06:44 PM   #906
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
1649 was assigned to Wayne and Lillie Longfellow of Pasedena, Calif. in the 1966 directory.
Back in post 550 (I think) I learned that Wayne and Lillie Longfellow of Pasedena, CA had our WBCCI numbers before we did. The NEU is having its 60th birthday this year and there will be people sharing stories from its origins. Made me wonder what WBCCI unit the Longfellows belonged to...
I've never been able to find much additional information on them except this information about their passing (she in 1973, he in 1980).
Wondering if there's anyone in CA who remembers this family? I'd love to learn more about them and their travels in their AS (whatever it was).
Name:	ImageUploadedByAirstream Forums1465256413.503191.jpg
ID:	263973Click image for larger version
Name:	ImageUploadedByAirstream Forums1465256429.343342.jpg
SteveSueMac is online now   Reply With Quote
Old 06-07-2016, 08:00 AM   #907
1962 22' Safari
2016 30' Classic
Images: 41
Hi all,
Thanks!
Since you have confirmed this number is on your 1971 Overlander, I will research #8815 from 1970 onward. Here is how #8815 has been assigned from 1079 onward:
1970: Directory published before your Airstream was built. Assigned to a couple named Williams. Did not look up their details or look further back.
1971: Unassigned.
1972-79: Parker & Irma Van Dien, Union, NJ (1972), Melbourne, FL 1979 (Irma only), no caravans. In 1979 Irma's address appeared to be at the Port of Call Airstream Park.
1980-87: Clifford & Wanetta Furton, Melbourne, FL 1980), Lake Park, FL (1987), no caravans.
1988-89: Unassigned.
1990-2004: Leroy & Naomi Jasmer, Willmar, MN, caravan, 226 - Eastern Canada Holiday 1995, and unit caravans U53, U194, U259, U293.
2005+: Unassigned (only checked a few, though).
So what can we tell from this? First, given that you live in Oregon and none of the previous assignee's were in or near Oregon, proximity is not a significant help.
Next, since #8815 was unassigned in 1970 and then reassigned in 1972, this is very appropriate for a 1971 Airstream that could have been bought new in 1971 after the 1971 Directory was published in January 1971. This makes it very reasonable that the Van Diem's may have owned your 1971 Overlander.
Then, given that there was no unassigned year between the Van Diems and the Furtons, and given that both lived in Melbourne, FL at the time, it seems likely that the Van Diem's sold their Airstream (whatever it was) to the Furtons.
Finally, Given the two unassigned years between the Furtons and the Jasmers and the multi state distance, it is much less likely that the Furton's sold their Airstream to the Jasmers. Most likely the Jasmers received #8815 as a random reassign of an unused number.
So, at least one of these three couples must have owned your Airstream. My best guess is that the Van Diem's and Furtons likely owned your 1971 Overlander, but not the Jasmers. It is less likely that either all three couples owned it or that only the Jasmers owned it. If you got any old paperwork, or found any old dealer decals on it, that might help you decide which state your Overlander may have previously resided in which could help you make a better guess as to who may have owned it.
If this evidence suggests the Jasmers may owned your Overlander, they may have taken it on the noted caravans.
That's all I got. Make some memories of your own in it!
Joe
WBCCI/VAC #6768
Old 06-07-2016, 08:19 AM   #908
1962 22' Safari
2016 30' Classic
Images: 41
Originally Posted by jimbro View Post
Hi Joe,
Hi Jim,
#15901 was first assigned in 1967 well before your 1985 Airstream MH was made. There has been a single couple that were assigned #15901 from 1976 to 2014: Thomas J & Joan Hancock of Ohio. I am not listing their city because of how recently they were members. Contact me via email of you need would like that detail. In any case, Ohio is quite a distance from Alberta, so who knows when or how your Airstream made it's way from the Hancocks to you.
Because they were already members before your 1985 MH was built, the Hancocks must have upgraded to it at some time during their membership, quite possibly when it was new in 1985. It is also possible that they upgraded to something else newer in the years that followed, but we have no way of knowing for sure because the club does not keep records of Airstreams owned by members. The Hancocks are not listed as participating on any numbered caravans.
That's all I can turn up. Enjoy that rare Airstream Classic motor home!
Joe
WBCCI/VAC #6768
Old 06-07-2016, 09:11 AM   #909
1962 22' Safari
2016 30' Classic
Images: 41
Steve & Sue,
The information you were previously provided about your WBCCI number 1649 and the Lonfellows was incomplete. You can see the article I had published in the May 2016 WBCCI Blue Beret magazine for a little more detail on the history of WBCCI numbers in general, but the short answer is that #1649 was first assigned in 1958 and interestingly, it was assigned to Wayne & Lillie Longfellow of Pasedena, CA at that time. The Longfellows were last listed in the 1971 Membership Directory, at which time they were still in Pasedena and were credited with only a single caravan: 18 - Western Canada Summer 1958.
#1649 was then unassigned in 1972 before being reassigned in 1973 to Horace & Catherine Gorton of Prairie Village, KS in 1973. A number as low as 1649 may have been reassigned several times since 1973, although I did not check. Given that you do not own a vintage Airstream that bears this number, but were yourself just randomly reassigned 1649 when you joined the club, there is little value in searching the complete assignment history of #1649.
It is unfortunate that unit numbers were not listed for members until the 1975 Directory. The very first unit was created in (in California) November 1955, just months after WBCCI was formed in August 1955. By 1971, the last year the Longfellows were in the club, there were 14 units in California alone. I even searched the Membership Directory Unit Officer listings for the years that the Longfellows were in WBCCI hoping for a match with one of the California units, but did not find anything. Apparently, the Longfellows were never officers in whatever unit they belonged to. Thus I have unfortunately exhausted my resources to possibly determine the Longfellows unit.
Good Luck with your search!
Joe
WBCCI/VAC #6768
Old 06-07-2016, 11:38 AM   #910
W , New England
Thanks Joe! What great info. Yes, I was just randomly assigned these numbers as a new member with a new trailer so my interest was in the people who had the number, not the history of the trailer.
I'd still love to find some information about the Longfellows but there isn't much available other than what I've already shared.
Thanks so much for the additional insights!
wbcci, wbcci number
WBCCI Membership for free thenewkid64 WBCCI Forum 17 05-01-2011 11:17 PM
WBCCI and local Units Stougard WBCCI Forum 54 02-28-2006 09:46 AM
WBCCI family/children/pet friendly? ViewRVs WBCCI Forum 66 01-08-2006 08:34 PM
WBCCI Survey smily WBCCI Forum 33 11-13-2005 10:08 AM
Membership in WBCCI winner General Motorhome Topics 5 01-08-2003 11:21 AM
