Old 06-23-2015, 09:11 PM   #827
albert's Avatar
1970 29' Ambassador
1959 22' Flying Cloud
1957 26' Overlander
Tulum , Mexico
Send a message via AIM to albert Send a message via Yahoo to albert
[QUOTE=albert;1641438]
Originally Posted by 66Overlander View Post
#1594 was first assigned in 1958. From then thru at least 1964 (didn't check further), it was assigned to Denis & Marie Aymard of San Francisco, CA. The Aymards and very likely this Airstream participated on Caravan 18 - Western Canada Summer
Attachment 241447Attachment 241448
Thank you so much! Now I need to figure out which model this trailer is. Owner says it's a 57, but is has dual axles, and is no longer than 22-24, the badge on the door says Land Yacht, but the badge looks new and probably not original. In my research, there is no dual axle that is that short, and none named land yacht in 57. Any insight would be appreciated!
Name:	ImageUploadedByAirstream Forums1435115507.386783.jpg
albert is offline   Reply With Quote
Old 06-23-2015, 09:58 PM   #828
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
[QUOTE=albert;1641439]
Originally Posted by albert View Post
Attachment 241450
If the body is about 24' long than this would be a 26' Overlander (overall length includes tongue & bumper), which could be ordered with optional dual axles. That seems most likely. If you can provide the serial number from the plaque by the door, we can confirm. There were a very few rare 22' tandem World Travellers made in 1958 & 59, but I do not believe this is one of them.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 06-23-2015, 10:33 PM   #829
Jimbcole's Avatar
1958 17' Pacer
Tryon , North Carolina
My guess would be a '58 Overlander.
Name:   ImageUploadedByAirstream Forums1435120411.389698.jpg
Jimbcole is offline   Reply With Quote
Old 06-24-2015, 12:51 AM   #830
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
#11154 is parked in Lewisville, Texas, old shadows of the numbers is what one sees.
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB / 2008 Dodge Cummins 4 X 4
WBCCI #4165 AIR #31871
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 06-24-2015, 12:45 PM   #831
albert's Avatar
1970 29' Ambassador
1957 26' Overlander
Tulum , Mexico
[QUOTE=66Overlander;1641463]
Thank you again! I was able to get more photos and learned that the wbcci number is 7594, not 1594. I stepped off 24' for the body length. I got the serial number (6936) Click image for larger version
Name:	ImageUploadedByAirstream Forums1435171294.832100.jpg
ID:	241493Click image for larger version
Name:	ImageUploadedByAirstream Forums1435171325.186139.jpg
ID:	241494Click image for larger version
Name:	ImageUploadedByAirstream Forums1435171356.026187.jpg
Name:   ImageUploadedByAirstream Forums1435171499.336632.jpg
from the door badge, see photos. Any help in finding the history and the model would be really helpful, as I hope to acquire this trailer but not before learning more about it. Thanks in advance!
Albert
Old 06-24-2015, 12:56 PM   #832
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
My guess would be that it's a '57 CA made Overlander with the Land Yacht package. During this era, Airstreams had three different packages; standard, Land Yacht and International. In this case because of the Land Yacht plaque, yours would have had an on-board battery, air compressor for the water tank and a few other items.
The style of windows also tell me its prior to 1959 and somewhere along the PO line, they've changed the Airstream nameplate on the ends to the newer block style lettering. The art deco style ones are available from Vintage Trailer Supply if you'd like to change them back. The factory changed them sometime during the early 1960 model year.
Check out RJ's vintage archives for more info:
1957 Overlander 26' - Vintage Airstream
Good luck on whatever you decide to do.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 06-24-2015, 06:43 PM   #833
1962 22' Safari
2016 30' Classic
Images: 41
[QUOTE=albert;1641738]
Thank you again! I was able to get more photos and learned that the wbcci number is 7594, not 1594. I stepped off 24' for the body length. I got the serial number (6936) Attachment 241493Attachment 241494Attachment 241495Attachment 241496from the door badge, see photos. Any help in finding the history and the model would be really helpful, as I hope to acquire this trailer but not before learning more about it. Thanks in advance!
Albert
This Airstream is a bit of a mystery. The serial # suggests it is a late 1957 or early 1958 California built 26' Overlander. The windows are typical of a 1956 or 1957 California build. The long streetside drip cap over the windows is typical of 1958. The wheel well shape is 1959 to 1961. The Land Yacht plaque is about 1959/60. And as noted already the Airstream plaques are typical of about 1960+. My best guess is late 57/early 58 that someone had modified (wheel well shape & badging) to look a few years newer.
Joe
WBCCI/VAC #6768
Old 06-24-2015, 08:09 PM   #834
1962 22' Safari
2016 30' Classic
Images: 41
#7594 is also more of a challenge. This number was first assigned in 1962, so not when the trailer was first made. What's more, by 1970 it had been assigned to at least three different members, and no way to tell who may have owned the Airstream. In any case, the first assignees were Lee & Phyllis Williamson of Trenton, Nebraska from 1962 thru 1965. The Williamsons were listed for caravan 32 - Eastern Mexico Winter 1963. In 1966 #7594 had been reassigned to someone from California. By 1970 it was assigned to someone from Arkansas. Unlikely that all owned the same Airstream. Not sure which one may of these or someone even later may have owned this Airstream. That's the best I can do.
Joe
WBCCI/VAC #6768
Old 08-23-2015, 06:27 PM   #835
1978 28' Ambassador
Mt. Aukum , California
#6851
Trailer is a 1978 Ambassador. Anything on it?
Tyler
CustomShop is offline   Reply With Quote
Old 08-28-2015, 04:15 PM   #836
1968 20' Globetrotter
Rumford , Rhode Island
Ghost Numbers
Hi folks:
I posted this recently but because I am a newbie, probably in the wrong place.
So I thought that I would try again.We just purchased a 1968 Globetrotter that has 2 sets of ghost numbers on it. The first set is 5409. No doubt because they are half there. The second set is 68. These numbers are spaced out but don't appear to have anything between them.
I know that the AS was in Connecticut in 2000 and who had it. There is a title that said it came from Florida.
Being the historian that I am, I would love to know the history of these numbers and in fact who might have owned our AS. It appears to have been bought from C.J. Stoll because his dealer plate is attached.
Oh and I did see in the first WBCCI directory that was published and online who owned #68. I know that number could have been reissued.
Layback
layback is offline   Reply With Quote
Old 08-31-2015, 10:38 PM   #837
EEC
EEC's Avatar
1969 31' Sovereign
Dover Foxcroft , Maine
Would appreciate any info on recently acquired 1969 31' Sovereign, WBCCI 17679, VIN I31T9J260.
thanks in advance,
Ed
EEC is offline   Reply With Quote
Old 09-04-2015, 08:15 AM   #838
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Not to come across as a "Party Popper", We need to be aware, & respectful of individual's privacy when talking & sharing previous owner's personal info..Especially on the internet..
Just saying..Vern
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is online now   Reply With Quote
Old 09-08-2015, 08:10 PM   #839
Westminster , Colorado
I have a 1959 Overlander with very clear #2828 stickers on it. I read about a previous person (not owner) in this thread who has a 76 with the same numbers. I would love the history on my trailer. Obviously, prior to '76 is what I'm looking for.
My husband was able to see today that there are scratches from where there was (what we have since deduced) a Wally Byam's plaque. I'm dying to know if there are records of my trailer having gone on a Caravan.
We haven't found any other stickers..or evidence of old stickers.
Also, where would the Overlander name plate have been? I don't see a place where rivets were removed. The Overlander plate is missing.
Thanks so much in advance!
Rachael
painterfam is offline   Reply With Quote
Old 12-15-2015, 10:30 AM   #840
AudioMike's Avatar
1966 22' Safari
Englewood , Colorado
This has been a very interesting read. In restoring my 66' Safari I havent given much thought to the Red numbers. I am interested to know more history on this trailer. Would someone be able to look up #17012 Thanks
Audiomike
1966 Safari
2001 Silverado 2500HD
AudioMike is offline   Reply With Quote
wbcci, wbcci number
WBCCI Membership for free thenewkid64 WBCCI Forum 17 05-01-2011 10:17 PM
WBCCI and local Units Stougard WBCCI Forum 54 02-28-2006 08:46 AM
WBCCI family/children/pet friendly? ViewRVs WBCCI Forum 66 01-08-2006 07:34 PM
WBCCI Survey smily WBCCI Forum 33 11-13-2005 09:08 AM
Membership in WBCCI winner General Motorhome Topics 5 01-08-2003 10:21 AM
