Go Back   Airstream Forums > Airstream Community Forums > Clubs, Organizations & Associations > WBCCI Forum
Old 01-31-2018, 11:38 PM   #1001
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Southeast , Michigan
Images: 41
Originally Posted by 66Overlander View Post
Hi Jewel,
I am not going to do a full lookup yet, because I can tell that WBCCI #12659 was not the first number on your 1963 Safari. The 12659 could not have been applied until 1965 or later.
I believe I can see the two center digits of a likely 4 digit number that was previously on your Airstream. The center two digits look like a "70" to me and assuming that the original number was first applied some time between late 1962 and early 1964, I will speculate that the lead digit might be a 6, 7, 8, or 9, but I can't see it in the photo. If you are able to determine the original full 4-digit number, that would likely correspond to the first owner of your 1963 Safari. Let me know.
Hi again Jewel,
The more I look at the photo, the more I think the original number started with an "8", thus making it "870X". See if you agree, because the number may be more visible from a different angle than the photo was taken. Also see if you can make out the last digit. I have no clue on that one.
Name:	Number Under 12659.JPG
Joe
WBCCI/VAC #702 & #6768
66Overlander is offline   Reply With Quote
Old 02-01-2018, 05:30 AM   #1002
1970 31' Sovereign
Anderson , Indiana
Hi, You are both new here, so I'll repeat what I have said a few times before. Researching old WBCCI numbers in decades of paper Membership Directories takes time. The task is made easier of I know the year of the Airstream the old "big red numbers" are on, because that can limit the number of Membership Directories that have to be searched. Thus, I only provide this service to those that post information about the Airstream as well as the WBCCI number they are inquiring about. Provide that information and I'll be happy to look up the number when I get some free time (no promise that it will be a quick turn around as I am very busy with other things). I hope this makes sense.
Mine is a 1970 31' sovereign. I would really think you only need to check 1970 -71 unless the history I was told was inaccurate.
# is 12383
dougsmiley is offline   Reply With Quote
Old 02-01-2018, 08:45 AM   #1003
1962 22' Safari
2016 30' Classic
Images: 41
# is 12383
Hi Doug,
Here is how #12383 was assigned from 1970 onward:
1970: Unnassigned.
1971-72: Carroll Adams, Mesa, AZ, no caravans.
1973-85: Herschel & Mary Lou McMahan, Indianapolis, IN (1973), Naples, FL:, (1985), no caravans.
1986: Unassigned. Did not check further.
Since you think you know the original owner name, I am hoping it is one of the names I provided. Being that you are from Indiana, it would seem that the McMahans from Indianapolis are more likely to have owned your Airstream than Mr. Adams in Arizona.
There is one curiosity though in that there was no unassigned year in between their memberships. Typically, WBCCI holds a number for a year before reassigning it in case the prior assignee(s) make a late decision to renew their membership. This waiting period can be waived by the prior assignee(s), and that most often occurs when they sell their Airstream and the new owner wants to immediately join the club with the same number.
What does this mean in your case? If you have an Ohio built Sovereign, probably nothing - the McMahan's were probably the first owners. However, if your Airstream is California built, it becomes more likely that Mr. Carroll was the first owner and may somehow have sold it "long distance" to the McMahans. Mind you, these are just guesses because the club did not keep records of the Airstream owned by members, but it is a fact that a 1970 Airstream sold new in Arizona was more likely to come from the California plant and one sold new in Indiana was more likely to have come from the Ohio plant.
I hope this helps. It would be interesting to hear if any of this confirms what you thought you knew. Enjoy your Sovereign!
Joe
Old 02-01-2018, 11:25 AM   #1004
1970 31' Sovereign
Anderson , Indiana
wonder if we discovered an error in the numbers. A duplicate issued or an error somewhere.
The Indianapolis owner makes sense. Ohio built and didnt do much traveling as far as i know.
I actually dont have any names i just know it sat on a campground at lake monroe for many years. It has changed hands but never left that spot since the McMahan's owned it.
Thanks for the info, all very interesting.
Old 02-02-2018, 08:32 AM   #1005
Las Vegas , Alaska
Thank you so much mine is on a 1966 overlander 26d.
66Heathen is offline   Reply With Quote
Old 02-08-2018, 07:16 PM   #1006
1970 31' Sovereign
Anderson , Indiana
Some confirmation of the information was found by the name plate, a sticker they had put on is still partially there.
Old 02-09-2018, 01:03 AM   #1007
1962 22' Safari
2016 30' Classic
Images: 41
Originally Posted by 66Heathen View Post
Do you anything on 5312?
Hi 66Heathen,
I suppose I should have guessed you had a 1966 Airstream from your forum name. In any case, thanks.
#5312 was first assigned in 1961, before your 1966 Airstream was built. Here is how that number has been assigned according to WBCCI Membership Directories over the years:
1962-1997: Wendel & Isabell Jones, Mansfield, OH, caravans 29 - Mexico Winter 1962, 33 - Eastern Canada Summer 1963, & 41 - Pan American Winter 1965.
1998-2000+: Unassigned (did not check further).
From this we can be pretty sure that the Jones' owned your 1966 Overlander, be we cannot be sure when. Did they upgrade to it when new in 1966, or did they upgrade to it as a used trailer at a later time. In any case, a 1966 Airstream is too new to have been used on any of their caravans.
That's all I got. Enjoy your 1966 Overlander. We miss our first Airstream from time to time. It was also a 1966 Overlander 26d.
Joe
Old 02-09-2018, 07:10 AM   #1008
KyBryanP
1978 31' Sovereign
Louisville , Alabama
Can you assist with research on #13359 please? Its a 1978 Sovereign International Land Yacht 31' Thanks!
KyBryanP is offline   Reply With Quote
Old 02-12-2018, 09:13 AM   #1009
Las Vegas , Alaska
Hi 66Heathen,
Thank you kindly
Old 02-13-2018, 07:55 PM   #1010
1957 26' Overlander
Antigo , Wisconsin
Ghost # 19207
Sorry for the slow reply. I've been very busy lately. #19207 was first assigned in 1967 thus first appearing in the 1968 WBCCI Membership Directory. Given that this is years after your 1957 Overlander was built, we cannot just assume that is when the number was applied to your Airstream. In any case, here is how #19207 has been assigned over the years:
1968-69: George & Beatrice Steckhahn, Menomenee Falls, WI, no caravans.
1970: Unassigned.
1971-76: Anthony & Mary Korenak, Brookfield, WI, no caravans.
1977: Michael G. & Beatrice Colwell, Menomonee Falls, WI, no caravans.
1978-Current: Unassigned (only spot checked a few directories after 1985)
So what can we guess from this? My guess is that all three couples in Wisconsin owned the same Airstream because of the close proximity of the cities they lived in. It must have been your 1957 Overlander.
I do wonder if Beatrice Colwell was Beatrice Streckhahn. If the Streckhahns dropped out of the club for 1970 because George passed away, I suppose Beatrice could have remarried re-bought the Overlander, and rejoined the club. Of course, this is only speculation. I have absolutely no proof. It just seems too much of a coincidence that two different women with the same first name in the same city would be assigned the same WBCCI number just a few years apart. It is possible, just seems unlikely.
Enjoy your Overlander!
Thank you for your time in researching this for us.
solinp is offline   Reply With Quote
Old 02-17-2018, 09:40 PM   #1011
KyBryanP
1978 31' Sovereign
Hello! Can someone please assist with research on #13359? Its a 1978 Sovereign International Land Yacht 31'. Is any additional info needed?? Thanks!
Old 03-08-2018, 01:45 AM   #1012
amysemmens's Avatar
1960 24' Tradewind
Heyfield , Victoria
I would love some help in finding some history on our Airstream. We imported it into Australia 3 years ago and apart from the person we bought it from, we don't know anything else. It's a 1960 Tradewind, serial number 24TS0560. Up until recently we didn't think it had ever had numbers, but upon stripping and polishing some very faint ghost numbers appeared. All we can make out at this point is 4--2. I realise this may not be enough info but would appreciate any help if possible. Many Thanks! Amy
amysemmens is offline   Reply With Quote
Old 03-13-2018, 12:08 AM   #1013
1962 22' Safari
2016 30' Classic
Images: 41
Hi,
WBCCI membership number 13359 was first assigned in 1965, well before your 1978 Sovereign was built. After the original assignees did not renew for 1974, #13359 was assigned as follows from 1975 onward:
1975-79: Kenneth B & Dorothy Kelsey, Plainfield, NJ (1975), Hyannis, MA (1979), no caravans.
1980-83: Unassigned.
1984-89: Roscoe & Lillian Brown, Lenox, IA, no caravans.
1990+: Unassigned, but only spot checked a few directories.
So what can we guess from this? It is doubtful that the Kelsey's and Brown's owned the same Airstream given the distance and unassigned years in between them. Given that you are in Alabama, that does make the guess more likely to lean toward a prior owner in either NJ/MA or IA, unless you can find a dealer decal on the trailer. Given that I do not know this detail, I cannot make a guess as to whether the Kelsey's or Browns were the more likely prior owner of your Sovereign, but I will say that it seems unlikely, though certainly not impossible that the Kelsey's would have upgraded to a new 1978 Airstream part way thru their membership period, but then dropped out of the club a couple years later.
That's all I got. Enjoy your Airstream!
Joe
Old 03-13-2018, 12:16 AM   #1014
1962 22' Safari
2016 30' Classic
Images: 41
Hi Amy,
The serial number 24TS0560 makes your Tradewind a 1961 model that was likely built in December 1960 or January 1961.
A 4-digit WBCCI number starting with a "4" would have been first assigned in late 1960 or early 1961, depending upon what the second digit was. Without the full 4-digit number I don't have enough information to do a search. Sorry.
You might try looking at the front and rear end caps from various angles under various lighting conditions. Some times the ghost outlines are there, but can only bee seen from certain angles. I have seen cases where owners could not see the outlines until they posted endcap photos and I could locate the faint outlines via the photos. Sometimes looking at a photos on a computer screen from various angles helps to locate the outlines.
Good Luck! Enjoy your 1961 Tradewind!
Joe
Old 03-17-2018, 09:58 AM   #1015
1962 22' Safari
2016 30' Classic
Images: 41
Hi again! I've been out in the dark with a torch, and I'm 99% certain the numbers are 4272. I can't make out each complete number but enough to know which each number is. I would be forever grateful for any info you had on these numbers!
Hi Amy,
per the above message quoted from your PM to me, here is what I found. WBCCI Membership Number 4272 was first assigned in very late 1960. Here is how that number has been assigned according to WBCCI Membership Directories over the years:
1960-84: Kendall & Gladys Howe, Bellevue, Washington (1960-63), Olympia, Washington (1964-84), no caravans (Gladys only in 1984).
1985: Unassigned.
1986-87: Virgil E. Elliot, Bellevue, Washington, no caravans.
1988: Virgil E. & Bette Elliot, Olympia, Washington, no caravans.
1989-2013: Bette Elliot, Olymipa, Washington, no caravans.
2014: Unassigned, did not check further.
So what can we guess from this? First, I will guess that the Howe's bought your late 1960 built 1961 Tradewind in late 1960 and immediately joined WBCCI being assigned #4272. I will also guess that Gladys Howe (or her family) sold an Airstream to Virgil Elliot in 1984 or 1985, because of the close proximity and same WBCCI number. Furthermore, the Elliot's Olympia, WA street address was exactly the same as the Howe's Olympia WA street address. That address is actually in the Washington Land Yacht Harbor Airstream Park. It is possible that Virgil Howe and Gladys Howe were related such that the ownership transfer was via a will rather than a sale, but that is just speculation.
What we can't know, though, is if the Airstream that transferred from Gladys Howe to Virgil Elliot was the 1961 Tradewind. Maybe yes, maybe no. It is certainly possible that the Howe's upgraded to a newer and possibly larger Airstream between 1960 and 1984. Since the club did not keep records of the Airstreams owned by members, I have no way of answering this question.
That's all I got. If you can confirm that the Airstream was bought from Washington state, that might help increase the certainty that the big red numbers were "4272" to something more than 99%.
Enjoy your Tradewind!
Joe
Old 04-06-2018, 04:20 PM   #1016
Tikihut's Avatar
1977 Argosy Minuet 6.0 Metre
schaumburg , confusion
Send a message via AIM to Tikihut
Hi everyone I am looking for some info on a number 3916. I found two ads for the same trailer I am interested in buying and think someone is trying to scam me. The person I have been emailing back and fourth has sent me extra pictures but then I found the same trailer I a different state that had the same number but this time I saw the license plate clear as day
I would really appreciate any help on this. It is a nice trailer I would like to buy
Thank you
Tikihut
Tikihut is offline   Reply With Quote
Old 04-06-2018, 11:33 PM   #1017
1962 22' Safari
2016 30' Classic
Images: 41
Thank you
Tikihut
Hi Tikihut,
Researching who was assigned the old "big red number" on an Airstream will not help you determine if an ad is legit or a scam. #3916 was first assigned in 1960 and may have been reassigned several times since then. Who knows when that number was put on that trailer. You haven't even indicated the year and model of the Airstream. Those details could narrow it down a bit.
Should the ad prove legit and you purchase the trailer I'd be happy to then look up who that number was assigned to over the years, but each case takes quite a bit of my time to do, so I wont do it in the current situation. Sorry.
Joe
Old 05-06-2018, 07:05 AM   #1018
1966 28' Ambassador
Wilmington , North Carolina
1966 Ambassador directory asst
Hi there, I just started fixing up a 1966 Ambassador # 6838 and would love help Finding the original owner, and perhaps other owners during that era and any caravan activity.
Thanks so much!!
Peetsie68 is offline   Reply With Quote
Old 05-09-2018, 05:19 PM   #1019
Santa Clara , California
Hi,
I'm still very new here so if this isn't the right place to ask this question please let me know.
I see a 2018 Flying Cloud 20FB for sale. It has the red 21509 numbers on the front and back. The salesguy says it was "used only once" and that the previous owner came in and traded it in on a boat. Is there a way I can tell any information about this? My concern is that if the owner bought it and found it had some major problems they may have traded it on on the boat. Is there any way any additional information about this Airstream could be found?
Thanks in advance!
Jon
rawman is offline   Reply With Quote
Old 05-10-2018, 11:31 AM   #1020
Aluminum in 3-D
Blue Pearl's Avatar
1968 28' Ambassador
Seaside , Oregon
The Club is very concerned about the privacy of our Members, but it does sound like the member has gone a different direction in his recreational pursuits. We've had some members buy an Airstream just to go on a Caravan, Special Event rally with the club or travel around the US for a year and then sell and go on to something else. No better way to explore the National Parks than an Airstream.
Since this is a new member from 2017-2018 we would not be able to give you their information, I'm sure you understand. The Dealer should give you the name or at least have the member give you a call if they wanted to. Also, any issues should still be covered by Airstreams Warranty. Go ahead, buy the Airstream, join the Club and go camping, you'll love it.
Teresa
Membership chair
Wally Byam Airstream Club
Past President Oregon Unit 090
Campfires, the original social media!
wbcci#29827
Check out the [URL="https://airstreamclub.org/"and Wally Byam Airstream Club on facebook
Blue Pearl is offline   Reply With Quote
wbcci, wbcci number
WBCCI Membership for free thenewkid64 WBCCI Forum 17 05-01-2011 10:17 PM
WBCCI and local Units Stougard WBCCI Forum 54 02-28-2006 08:46 AM
WBCCI family/children/pet friendly? ViewRVs WBCCI Forum 66 01-08-2006 07:34 PM
WBCCI Survey smily WBCCI Forum 33 11-13-2005 09:08 AM
Membership in WBCCI winner General Motorhome Topics 5 01-08-2003 10:21 AM
