Old 07-17-2013, 11:02 AM   #533
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
17218 on a 1975? Sovereign located in Michigan.
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
Old 07-19-2013, 05:23 AM   #534
Gilmurr's Avatar
1998 30' Excella 1000
Halifax , Nova Scotia
Anyone have info on 4636 ....it is faintly visible on the front and back. Thanks all
David & Andrea
'98 Excella 1000 Classic 30ft
2007 Toyota Tundra Dbl Cab
Gilmurr is offline   Reply With Quote
Old 07-19-2013, 09:06 AM   #535
Jimbcole's Avatar
1958 17' Pacer
Tryon , North Carolina
17218 is listed at Robert and Virginia Dinsmore, Vassar, Mi in the 1976 WBCCI directory
Jimbcole is offline   Reply With Quote
Old 07-20-2013, 10:59 AM   #536
dkrug's Avatar
Bad Axe , Michigan
Thank you for all the research you do!
1947 Spartan Manor
Old 08-08-2013, 12:43 PM   #537
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Ghost number 5344.
We have a 1965 Tradewind with ghost number 5344. Could we find out any information you may have on this. The trailer was purchased in AZ and had a previous plate from AZ.
Thanks in advance for you response and for all the research you do.
Name:	130502 (151).jpg
ID:	192707   Click image for larger version
Name:	130502 (152).jpg
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 08-12-2013, 12:34 PM   #538
1972 27' Overlander
Bothwell , Ontario
I am also hoping someone will have some input on our trailer's numbers. We have a 1979 Overlander that has two numbers on it, the more recent number is 14202 and the ghosted number underneath is 30248.
thanks,
Greg
gwstorrey is offline   Reply With Quote
Old 08-12-2013, 06:55 PM   #539
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
I do not believe the number is 5344. If so, it would not be centered on the end cap. The spacing suggests that there should be a leading "1" or "2" (but cannot be higher, because the highest number ever assigned was under 35000).
I think I may see the top of a "2" in front straddling the panel seam, possibly making the actual number 25344. On the other hand, #15344 would have first been assigned in 1966, not necessarily inappropriate for a 1965 Airstream. #25344 was first assigned in 1971. If you can confirm which it is, I can look the number up for you.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 08-12-2013, 07:12 PM   #540
1962 22' Safari
2016 30' Classic
Images: 41
thanks,
Greg
#30248 was first assigned in 1976. In 1978 and 1979 it was assigned to Amouel & Mary Singleton of New Albany, IN, no caravans. The Singletons did not renew in 1980. I spot checked a few later directories and it does not appear that #30248 was ever reassigned.
#14202 was first assigned in 1965, but our concern is post 1979. #14202 was unassigned in 1980 thru 1983, before being reassigned to Geoffrey & Glenda Shilleto of London, ON in 1984 & 1985, no caravans. It was then unassigned thru at least 1989. I spot checked a few directories after than and it appears that #14202 may have never been reassigned, although my checks were not comprehensive.
It thus seems very likely that your 1979 Overlander was owned by both the Singletons and the Shilletos.
Joe
WBCCI/VAC #6768
Old 08-12-2013, 07:20 PM   #541
calais66's Avatar
1951 21' Flying Cloud
Sacramento , California
Looking to research some numbers for a friend of mine's AS: 9369 on a mid-sixties Safari. Thanks!
calais66 is offline   Reply With Quote
Old 08-12-2013, 08:48 PM   #542
1961 28' Ambassador
Mesa , Arizona
Thank you Joe, I looked back at all my photo's and zoomed in as best I could. Now that you mention it I also see the spacing issue and can see a light shadow by the seam that could suggest a possible number. I will look in person in a few days as it is high in the air for now and then I will get back to you.
thanks for your work.
Hittenstiehl
Old 08-14-2013, 04:45 AM   #543
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
30248 belonged to Amousel Singleton from Albany, NY, in 1979, but they only stayed as members for one year. In 1983, 14202 belonged to Dave Reynolds from Moines, IA
Old 08-14-2013, 05:36 AM   #544
1962 22' Safari
2016 30' Classic
Images: 41
Dwight,
Sorry to correct you, but Dave Reynolds was #14204, not #14202! I already provided the correct information in post #540 above.
Joe
WBCCI/VAC #6768
Old 08-15-2013, 07:10 PM   #545
64Lincoln's Avatar
1964 22' Safari
I have a '64 Safari with the ghost numbers of 12477. Can anyone help me with that?
64Lincoln is offline   Reply With Quote
Old 08-16-2013, 06:12 AM   #546
1976 25' Tradewind
Courtice , Ontario
Now I'm curious about mine......2445. I believe the trailer may have been originally from the Montreal area....
Trvlmn is offline   Reply With Quote
wbcci, wbcci number
WBCCI Membership for free thenewkid64 WBCCI Forum 17 05-01-2011 10:17 PM
WBCCI and local Units Stougard WBCCI Forum 54 02-28-2006 08:46 AM
WBCCI family/children/pet friendly? ViewRVs WBCCI Forum 66 01-08-2006 07:34 PM
WBCCI Survey smily WBCCI Forum 33 11-13-2005 09:08 AM
Membership in WBCCI winner General Motorhome Topics 5 01-08-2003 10:21 AM
