03-06-2013, 09:30 AM
#501
1962 22' Safari
2016 30' Classic
Southeast
, Michigan
Originally Posted by Sheldon
joe, any info on wbcci #2674, 1956 bubble. has pikes peak airstream club decal front and back.
thanks, LEW
#2674 was first assigned by the club in 1959, at which time it was assigned to Willard and Josephine Davis or Colorado Springs, CO. The Davis' are listed for this number thru the 1963 Directory, but without any noted caravans. In the 1964 Directory, #2674 has been reassigned to another couple from Minnesota. It seems likely that the Jones' owned your 1956 Bubble. Enjoy it!
Joe
WBCCI/VAC #702 & #6768
03-06-2013, 08:23 PM
#502
1977 31' Sovereign
1989 34' Excella
Johnsburg
My '63 Overlander was purchased new from the dealer in Mesa Az. and was built in Ohio.
03-06-2013, 08:32 PM
#503
1957 26' Overlander
Los Angeles
Originally Posted by 66Overlander
I agree that the number is clearly 326 from the photo. But that makes this one a toughie. As Grand Master noted, this number was assigned to Dave and Anna Mae Jones of Walteria, CA in the 1955 thru 1958 Membership Directories, but only the Winter 1955 Caravan #5. The issue here is that a 1957 Overlander could not have been used on a Winter 1955 Caravan that would have been run in Jan-Fed 1955. That means that if the Overlander belonged to the Jones', they upgraded to it some time after that caravan and then left the club at the end of 1958.
Another possibility is that this number was applied to the Overlander by a later owner. #326 was unassigned in the 1959 and 1960 Directories, but was then reassigned in the 1962 Directory (there was no 1961 Directory) to David and Jean Varran of Pontiac, Michigan. #326 was last assigned to the Varran's in the 1979 Directory, at which time they were in Ellerton, FL and were credited with the following caravans: - 59 - Maritime Province Eastern Canada Summer 1968
- 66 - Western Mexico Summer 1969
- N4 - Post International Rally Caravans 1975
- N5 - Post International Rally Caravans 1976
After 1979, #326 was reserved for usage by club officers, so I beleive that either the Jones' or the Varrans owned the Overlander, but unless there is supporting evidence that confirms a prior owner name or caravan participation, we are left to speculate which couple owned this Airstream. Given the distance between them, I think it unlikely that both couples owned the Overlander. If the Varrans owned the Overlander, it could have been for their entire time in the club, or only for a portion of their time in the club, so it may or may not have participated on the noted caravans.
One other consideration is whether the Overlander was built in California or Ohio. A California built Overlander would tend to suggest the Jones' most likely owned it, but an Ohio built Overlander would tend to suggest the Varrans most likely owned it. Since you have stated that it is an Ohio Overlander, I tend to lean toward the Varran's owning it and it somehow moving to California in the years after they owned it. That said, because there were differences between California and Ohio Airstreams back then, it is also possible that the Jones' originally purchased an Ohio Airstream because they preferred it or maybe because they could just get it quicker if the California plant was backed up. Or maybe they traded to it during a trip to the eastern US when they were closer to the Ohio factory. We may never know the answer.
That's all I got.
In any case, enjoy your Vintage Airstream!
Thank you, Joe! I agree with you that the Varran's must have owned my Airstream- there is the ghost of a sticker on the front from a trailer dealer in Pontiac, Michigan (incidentally this appears to be just a few hours from the factory in Jackson Center, I wonder if it was a large dealer at the time?). Somehow the trailer ended up in Montana, that's where she was when I bought her.
I do wonder if she was on any of the caravans you mentioned with the Varran's? I guess we'll never know. Thank you sincerely for this great work you do! I love learning more of the history (even possible history!) of my trailer!
03-07-2013, 05:07 AM
#504
1962 22' Safari
2016 30' Classic
Southeast
, Michigan
I would say your Overlander definitely was owned by the Varran's because of the Pontiac, MI dealer sticker. We just don't know whether they bought it new in 1957, or perhaps used in about 1961 (so that they first appear in the 1962 membership Directory).
Interestingly, our first Airstream, a 1966 Overlander, had the same sticker because Warner Trailer Sales is where it was originally sold! I do not know how big they were or when they went out of business, but I have driven by the location that they used to be many times. I know the location because the original owner of our first Airstream was Lorrie's parents and they pointed out the location to us. Lorrie's parents were good friends with Cal Warner that owned the Airstream dealership.
Joe
03-18-2013, 06:51 PM
#505
1956 16' Bubble
Adrian
, Michigan
# 2674
Joe, the original owners sold my Bubble to a couple in Minnesota. Do you have name and address of this couple in 1964 directory. Sounds like the new owners wanted to keep same club numbers. Thanks, Lew
04-02-2013, 11:30 AM
#506
Pet Sitter Extraordinaire
1989 33' Land Yacht
Chattanooga
, Tennessee
Can anyone give me any information for #9892? There are also 3 decals beside the numbers, which I think means that the previous owners were officers in the WBCCI. Thanks!
04-07-2013, 09:55 PM
#507
1969 29' Ambassador
Liberty Township
, Ohio
Looking for info on #22003. Thank you!
04-14-2013, 01:22 PM
#508
1958 17' Pacer
Tryon
, North Carolina
When you have time could someone give me some information on 2216 for a 1958 Model. The unit must have been near the Washington DC area from what I found inside. Thanks for your time!
04-19-2013, 04:24 PM
#509
1964 19' Globetrotter
1961 22' Spaceliner
Springville
, Utah
Hello could someone please give me WBCCI information on two different Tradewinds. One is a 1960 with ghost number 1356, and this one also has a caravan decal. The other is a 1959 with a ghost number 4003, no caravan decal. I am guessing the numbers are as old as the trailers. Thanks so much for this info.
Globestream
1964 Globetrotter
1961 Spaceliner
Utah
05-21-2013, 09:49 AM
#510
1961 22' Spaceliner
Springville
, Utah
Hello all,
Does anyone have a members guide from the early sixties, that could help me find information on the above numbers? 1356, and 4003. Thank you.
B
Globestream
1964 Globetrotter
1961 Spaceliner
Utah
05-21-2013, 02:18 PM
#511
1977 31' Sovereign
1989 34' Excella
Johnsburg
1356 is listed in the 1964 Directory as belonging to Arthur and Alice Horn from El Paso, TX.
4003 is listed to Pleasant but not in the alphabetical list. ??
2216 is listed to Harry and Ruth Hawkins from Clifton, VA
22003 is listed in the 1970 directory as belonging to Gilbert and Gladys McCollum From LsPort, TX.
9892 is listed in 1970 as belonging to Mauurice and Marierie Marshall from Briansbridge, NY
2674 is listed in the 1964 Directory as belonging to Noel and Ruby Lutsey from Minneapolis Min.
05-21-2013, 07:31 PM
#512
1961 22' Spaceliner
Springville
, Utah
Thanks dwightdi
I might have guessed that 1356 was from Texas (other decals on the trailer). Any mention of rallies?
Maybe Pleasant (4003)shows up in other guides, I'll keep looking.
Thanks again, for the info.
B
Globestream
1964 Globetrotter
1961 Spaceliner
Utah
05-21-2013, 08:02 PM
#513
1958 22' Flying Cloud
Lincoln City
, Oregon
My original Ghost numbers were 3667 on our 1958 Flying Cloud. We re-numbered when we joined the WBCCI to 4346. Any records on our original club numbers?
Dick
05-21-2013, 08:08 PM
#514
1957 26' Overlander
Winston Salem
, North Carolina
Any info on 4770? These are the ghost numbers on my '57 Overlander. Thanks!!
05-22-2013, 10:07 AM
#515
1977 31' Sovereign
1989 34' Excella
Johnsburg
3667 is listed in the 64 directory as Harry and Emmy Delacy and went on the 1960 Mexico /Caravan and the 62 Western Canada caravan.
4770 is in the 64 directory as Durbin with no alphabetical listing.
4003 is listed in the 74 directory as Ed Erickson from Olympia, WA with no caravans
05-22-2013, 10:59 AM
#516
1961 22' Spaceliner
Springville
, Utah
Originally Posted by Globestream
Thanks dwightdi
B
Rallies, oops, I meant Caravans. The Tradewind that I am looking at(1356), also has a Caravan decal.
B
Globestream
1964 Globetrotter
1961 Spaceliner
Utah
05-22-2013, 11:01 AM
#517
1969 27' Overlander
Northeast
, Georgia
Does anyone have information on the number 4383? This number is on our 69 Overlander.
05-22-2013, 11:39 AM
#518
1977 31' Sovereign
1989 34' Excella
Johnsburg
1356 - The Horns went on the #16 and 19 caravans to Mexico in the winters of 58 and 59.
4383 is listed in the 1974 Directory as Gordon and Thelma Meisel from Prescott, AZ. No caravans listed.
05-22-2013, 12:42 PM
#519
1961 22' Spaceliner
Springville
, Utah
You rock dwightdi.
Thanks a ton.
B
Globestream
1964 Globetrotter
1961 Spaceliner
Utah
05-22-2013, 01:07 PM
#520
1969 27' Overlander
Northeast
, Georgia
Thanks so much!
