Old 04-12-2014, 04:29 PM   #1
1987 25' Sovereign
Oregon , Ohio
removing glue left from red numbers
I am changing our WBCCI numbers. A heat gun allowed me to peel off the numbers but left the glue. What can I use to dissolve and remove the residual glue?
msmcv51 is offline   Reply With Quote
Old 04-12-2014, 04:47 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Try Acetone in a small area. Preferably and area that will be covered with the new number.
2004 Excursion 4x4
Old 04-12-2014, 06:31 PM   #3
hutch309.2
hutch309.2's Avatar
1983 34' Limited
Amherstburg , Ontario
I think it would be safer to use mineral sprints or another product called Varsol ready available at any hardware store.
hutch309.2 is offline   Reply With Quote
Old 04-12-2014, 06:41 PM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Wouldn't acetone be a little aggressive on the clearcoat?
AtomicNo13 is online now   Reply With Quote
Old 04-12-2014, 08:24 PM   #5
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Use Goo Gone, but a soft rag.
I messed up my trailer removing the "green" sticker with a pot scrubber sponge. The "Thor" sticker came off easily with no damage or residue. Click image for larger version
Name:	ImageUploadedByAirstream Forums1397355782.995185.jpg
ID:	209562Click image for larger version
Name:	ImageUploadedByAirstream Forums1397355804.393428.jpg
ID:	209563Click image for larger version
Name:	ImageUploadedByAirstream Forums1397355823.385824.jpg
ID:	209564Click image for larger version
Name:	ImageUploadedByAirstream Forums1397355855.560598.jpg
ID:	209565I will leave the other stickers alone. I have not put on my big red numbers yet.Click image for larger version
Name:	ImageUploadedByAirstream Forums1397355622.897951.jpg
ID:	209559Click image for larger version
Name:	ImageUploadedByAirstream Forums1397355656.683448.jpg
ID:	209560Click image for larger version
Name:	ImageUploadedByAirstream Forums1397355685.855923.jpg
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-13-2014, 02:25 AM   #6
'06 75th Winick Prototype
2006 19' International CCD
1968 22' Safari
The Swamps of Hell , Lousy-Anna
Use Nu-Finish. It is a GREAT polish, but it also has an amazing ability to remove adhesive residue; not many polishes do this. It will remove sap, bugs, black streaks, gum, and old sticker residue relatively easily. It also removes light scratches and haze, and makes the surface afterward completely slippery with no swirl marks whatsoever...and no residue left behind. it contains no silicone nor any wax. It is frequently used as the last polish on new finishes to remove the lightest scratches and haze. It is AMAZING stuff.
ggoat!!! is offline   Reply With Quote
Old 04-13-2014, 05:52 AM   #7
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
X1000000000 on the NuFinish
Old 04-13-2014, 09:35 AM   #8
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Bestine.
The only thing we ever use on glue residue - works when nothing else will.
As a matter of fact, I used it yesterday to remove baked on duct tape "goo", leftover from having our broken window covered up all winter. Fixed the window - ready for spring!
Shari
Old 04-13-2014, 11:22 AM   #9
2014 23' Flying Cloud
Reed Point , Montana
Sticker B-Gone
I'm a person that really dislikes advertising on my new truck, airstream....etc.
So I read all the great advice for removing my new (month old) Airstream FC stickers and opted for the blow dryer, goo gone technique for removing the "Thor" sticker.
This sticker looked like a challenge, really well glued in place.
I applied medium heat with a blow dryer for about 60 seconds and it peeled right off with no residue left behind, didn't even need to use the goo gone.
I did "clean" wipe the spot with T-9 just for sport and it looks like nothing was ever there.
Bigskyrider8 is offline   Reply With Quote
Old 04-13-2014, 01:20 PM   #10
m.hony's Avatar
2013 30' Classic
The Thor sticker did leave without a trace. That "green" sticker, on the other hand...
TAC #MS-10
Airforums #70955
Old 04-14-2014, 12:22 PM   #11
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Never Acetone! Acetone will dissolve the clear coat on the trailer. I just removed my numbers to sell the trailer. Goo Gone and Meguires Cleaner Wax did the trick. No residue, no ghosting.
Randy
Randy and Pat Godfrey
Region 3 2nd VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 04-15-2014, 07:48 AM   #12
1987 25' Sovereign
Oregon , Ohio
Thanks for the tips. I have tried Nu-Finish, Goo Gone, and 30 year old mineral spirts. All of them softened it to some extent. I just called headquarters in Jackson Center, They said to use WD40 then wash with soap and water then dry. I will try that next when the snow melts tomorrow and if that does not work it's back to the drawing board.
Old 04-15-2014, 12:30 PM   #13
InsideOut's Avatar
1956 22' Safari
Images: 108
Bestine.
Old 04-15-2014, 12:34 PM   #14
m.hony's Avatar
2013 30' Classic
I tried WD-40 first. It didn't work.
Ronsonol lighter fluid has worked for me.
Goo gone is what I have successfully used lately- Saturday-
TAC #MS-10
Airforums #70955
Red! Red! Red! Can Anyone Tell Me What This is About Now? Fly at Night Batteries, Univolts, Converters & Inverters 23 11-06-2011 01:18 PM
Removing Vinyl and Glue-Inside or Out Leya Costa Clearcoat, Exterior Paint & Trim 4 07-07-2008 12:14 PM
Removing Vinyl and glue residue Leya Costa Upholstery, Blinds, Walls & Interior Finishes 2 05-16-2008 08:26 AM
Need advise removing fuzzy ceiling carpet glue JoeF Member Introductions 6 10-24-2007 10:36 PM
Removing Sticker Glue Cracker Cleaning, Stripping & Polishing 25 06-07-2007 03:57 AM
