Old 08-22-2015, 03:02 PM   #1
skitique's Avatar
1974 Argosy 26
1990 34' Excella
Charleston , South Carolina
Old Number Removal
Any ideas on how to remove the sticky residue of old numbers off our AS?
Not excited about putting our #s on the trailer after the struggle to clean off the old ones. Will we be the redneck members if I put these on a board & just put in the front window when at rallies?
skitique is offline   Reply With Quote
Old 08-22-2015, 03:19 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Only if you listen to Jeff Foxworthy CDs at the rallies.
I can't speak for the whole club, but as far as I'm concerned, as long as you show your numbers front and back, it doesn't much matter how you show them. The reason why the numbers are important is that in the event you need emergency services such as an ambulance, you want to make sure they can find you and not spend fifteen extra minutes looking for one shiny trailer out of a whole flock of them. So as long as they're easily visible, that's all that really matters.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-22-2015, 03:59 PM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Charcoal lighter fluid does a decent job without damaging the clearcoat. Dampen a soft cloth and hold it in contact with the residual glue till the glue softens a bit. A little rougher cloth will abrade the soften glue without disturbing the clearcoat.
Many members put the numbers on a clear piece of plastic and hang them or put them in the windows. At the International, you have to display your entry pass in side window.
Old 08-22-2015, 04:10 PM   #4
Boxite's Avatar
2008 22' Sport
WD-40 will remove old adhesive... So will acetone.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 08-22-2015, 04:16 PM   #5
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Not a thing wrong to be RedNeck members. Put 'em on a board, and display them if that's what you want. If anybody gets "stiff necked" about it, mention to them the reason why you do it that way.
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 08-22-2015, 05:14 PM   #6
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I don't remember the title of the thread but there's discussion about this somewhere in here - some folks have put their #s on a plexiglass sheet they suction cup to the window when they're at a rally. I've even seen one guy who has a custom neon sign he puts in his window 😄
Old 08-22-2015, 07:40 PM   #7
StreamRollin's Avatar
1999 25' Safari
Denver , Colorado
I just got done waxing the whole AS today and I had to replace one of my numbers because it was peeling off. I used GOO OFF which worked very good , along with some elbow grease
Jim D.
AIR # 56543 TAC# CO-10
StreamRollin is offline   Reply With Quote
Old 08-25-2015, 09:36 AM   #8
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
When you get the old numbers off you will still probably have "ghosts" from the numbers. I use fine steel wool to exorcise the ghosts, which of course does also affect whatever is left of the clear coat but imho looks better anyway.
Old 08-27-2015, 04:08 PM   #9
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I'm not familiar with Goo Off, but Goof Off is very aggressive. I used it on one of my plastic vent fan lids when I was trying to remove the gray paint that one of the POs had used on it and it attacked the plastic. Goo Gone, on the other hand, was OK on the plastic but not terribly effective.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 09-02-2015, 04:58 PM   #10
1988 32.5' Airstream 325
calgary , alberta
You may want to try heat gun to peel letters then Mayonnaise if that does not take off the glue then wd40 then clean with liquid dish soap and water
jhenry is offline   Reply With Quote
Red Number Removal cmmorsey Cleaning, Stripping & Polishing 9 06-15-2014 01:46 PM
Seal Part Number I am repacking wheel bearings and seals have no part number. Ditter Wheels, Hubs & Bearings 9 05-05-2013 02:17 PM
Old, old, old airconditioner removal bilby05 Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-17-2012 04:19 PM
number/ old owner search gparker WBCCI Forum 13 11-01-2006 12:21 PM
