Old 04-30-2012, 07:46 PM   #1
Florida 55's Avatar
2008 27' Safari FB SE
Pfafftown , North Carolina
Images: 42
Numbers for a Baldy #1
After purchasing our 2008 Safari SE 27FB in August 2011 we joined the Carolinas unit of the WBCCI. My DW determined she did not want to spoil the pristine skin of our new family addition, Sweet Pea, so we did not rush to put our red numbers on the trailer. We are planning to visit an Airstream only park that requires the numbers be displayed when camping. I went on a search for alternatives to putting the numbers directly on the skin and risking ghosting for some future owner.
After reading about "baldy" options on the forums, and using a Google search, I decided the plexiglass with suction cups method was the perfect solution for our baldy to be allowed to participate in WBCCI events. My daughter photographed the construction process to share with other Airstreamers.
From Lowes I purchased an 18" by 24" (3/16" thick) sheet of acrylic. I bought the more expensive acrylic instead of regular plexiglass in the anticipation it will last longer. The large clear suction cups with attached wire hook came from Home Depot (3 to a pack). The WBCCI logo and peel off adhesive numbers came from the WBCCI.
Tools used were a T-square, a regular square, a metal yardstick, and a black Sharpie pen medium point. Originally I tried using a fine point Sharpie but found it did not write well on the milky plastic protecting the acrylic sheet. An electric drill was used to drill holes in the sheet for the suction cup hangers.
My first step was to do a rough lay out using the number decals on the sheet (Picture 1). I next measured the numbers and calculated the spacing between each number, the spacing around the perimeter, and spacing between the logo and the numbers. With these calculations I used my T-Square, metal yardstick, and Sharpie to create a diagram on the protective cover sheet of one side of the acrylic (Picture 2). In Picture 3 you can see the completed diagram with the WBCCI logo not permanently placed on the sheet to demonstrate proportions.
ID:	157221   Click image for larger version
Chuck
Airstream - 2008 Safari 27FB SE (Sweet Pea)
TV - 2011 Ford F250 Lariat, 6.7 Diesel, 4X4 (Brutus)
TAC FL-55 | WBCCI 3823 - Unit 12 | AIR 48265
Florida 55 is offline   Reply With Quote
Old 04-30-2012, 07:58 PM   #2
Florida 55's Avatar
Images: 42
Numbers for a Baldy #2
The next step (Picture 1 below) was to drill holes in the plexiglass for the suction hooks. The holes should be drilled before peeling off the protective coating from either side. Use the suction hooks to determine the size of hole and placement. I decided to put three hooks across the top of the sheet (3 holes) and two at the bottom (two hooks at the bottom to keep the sheet from flapping in the breeze).
I then removed the milky plastic coating from the "clean" side of the acrylic sheet not marked with the diagram (Picture 2).
Now for the tricky part, applying the numbers and the WBCCI decal to the now "bare" side of the acrylic sheet (Pictures 3 & 4). The plastic from which the numbers are made is very stretchy once the backing is peeled off. It is very difficult to place the stickers in the locations on the diagram visible through the clear sheet. Air bubbles are also a problem. I can't imagine standing on a ladder applying these numbers to a trailer!
ID:	157224   Click image for larger version
ID:	157227   Click image for larger version
Chuck
Old 04-30-2012, 08:15 PM   #3
Florida 55's Avatar
Images: 42
Numbers for a Baldy #3
Once the numbers were adhered to the proper positions on the bare side of the sheet, the WBCCI logo was aligned to the diagram visible through the clear side of the sheet (Picture 1) and applied to the surface. It is a more stable decal and easier to handle than the numbers although I did experience some trouble removing the backing. The next photo (Picture 2) shows the finished acrylic sheet without the backing removed from the opposite side.
The final Picture 3 shows the finished sheet mounted to the front window of our trailer using the suction cups. Given that it was not a windy day only the top three suction cups were used to hold the sheet for the photograph. As mentioned previously there are two additional holes on the bottom of the sheet for two more suction cups which will keep it from flapping in the breeze.
With the assistance of my daughter this project took about 1 1/2 hours to complete. The sheet will be stored inside a pillow case for protection against scratches when it is not being displayed at WBCCI events.
ID:	157229   Click image for larger version
Chuck
Old 04-30-2012, 09:19 PM   #4
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Saskatoon , Saskatchewan
Images: 30
It looks great.
Lisa
Lisa and Paul
2008 23' Int. CCD "The Atomic Pod" https://atomicpod.wordpress.com
2002 Chinook Destiny | 1973 13' Boler (fiberglass egg) "The Boiler"
WBCCI #23223 (=23 CCD)
bolerama is offline   Reply With Quote
Old 05-01-2012, 07:12 AM   #5
rd tighe's Avatar
2007 25' International CCD FB
We are , Relaxed
Images: 12
Your job looks great! If you leave your #s on when we see you on the road we know who we are flashing our lights at. We have our WBCCI book with us at all times when we are on the road.
Richard (Dean) Tighe
W.B.C.C.I. 5617
2007 25' fb International Solar
2007 Dodge
Looking for Galt's Gulch
rd tighe is offline   Reply With Quote
Old 05-01-2012, 07:18 AM   #6
xo1rider's Avatar
2012 27' FB International
Fremont , California
Great job but where was this post 10 days ago when I was up on the shaky ladder in 85 degree blazing hot sunlight trying desperately not to have the "6" fold itself in half?
"The bad news: there is no key to the universe.
The good news: it was never locked."
Swami Beyondananda
http://polakoff.com/RamblinRose/
Our travel log
xo1rider is offline   Reply With Quote
Old 08-16-2012, 08:56 AM   #7
mefly2's Avatar
2015 25' FB Eddie Bauer
My alternative is to put some aluminum stock on the top / back of the clear plastic (as was done above) and then velcro the aluminum (either angle or channel) to the top of the frame of the front window rock guard.
Old 08-26-2013, 07:46 PM   #8
2014 Sport 22
2014 22' FB Sport
Patterson , California
We chose displaying our numbers in the back window on a sheet of plexiglass - so it can be seen while traveling yet not be on the skin of the trailer. We have a second one for the front window of the trailer.
ceallaigh is offline   Reply With Quote
Old 08-18-2014, 02:32 PM   #9
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Just tagging in so I can find this again. will undertake as soon as I can get to the city and find some Plexiglass....
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 08-20-2014, 03:09 PM   #10
1996 25' Excella
Tillsonburg , Ontario
Why not just put the numbers on the window front and back
JCWDCW is offline   Reply With Quote
Old 08-21-2014, 03:08 PM   #11
mefly2's Avatar
Finally caved and put the numbers on the new AS ... just the front ~1.5 hrs on the ladder! However, we will likely still use the plexi on the backside numbers - it has worked well for us over the pat 4 years ...
Old 08-21-2014, 03:58 PM   #12
Arcticfox's Avatar
Central , Canada
Your a brave sort - I still think I'm going the plexiglass route. I just don't know if I want the sheet as big as mentioned earlier in this thread of 18" x 24". If one did not bother with the WBCCI logo one could cut the size required for the plexiglass a lot I think.
Old 08-27-2014, 01:07 PM   #13
mefly2's Avatar
Yes, a bit smaller if you don't put on the circular logo ...or, just position it at the same level as the numbers.
Old 08-28-2014, 04:26 AM   #14
Florida 55's Avatar
Images: 42
You can definitely reduce the size of the plexiglass. I used a stock sheet of plexi from Lowes and didn't want to cut it. We store it in a pillowcase in between the queen bed and the closet next to the bed in our Airstream so it is protected from scratches and is out of the way when not in use.
We've only used it a few times. Top of Georgia Airstream Park requires the numbers be displayed. There have been a few WBCCI rallies where numbers are requested for identification purposes. Otherwise, we prefer the "clean" look when camping.
Chuck
