Old 04-30-2012, 08:26 PM   #15
casa3805's Avatar
Corpus Christi , Texas
Images: 41
Love it, still trying to work up the courage to put ours on. 3 8 0 5. Not going to be easy...
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
casa3805 is offline   Reply With Quote
Old 05-11-2012, 08:57 AM   #16
pyanke's Avatar
1985 25' Sovereign
St Cloud , Minnesota
I can relate. Our number is 7 5 2 8
Pete
WBCCI #7528
MN Unit
pyanke is offline   Reply With Quote
Old 05-21-2012, 12:34 AM   #17
Safari Streamer's Avatar
2015 28' Flying Cloud
Ladson , South Carolina
had ours made at a local sign shop - one piece - easy on and still lookin' good
2555!
Kathy Narowski
#2555
SC Coastal Unit
TAC-SC5
Safari Streamer is offline   Reply With Quote
Old 05-21-2012, 05:25 AM   #18
StreamNTyme's Avatar
2007 25' Safari FB SE
Carolina Low Country , South Carolina
Images: 27
I guess we should get around to putting some on, third Airstream though. Not our favorite job, but it is on the list. Maybe on plexiglass like we have seen. Then we can take it with us if we get another 'stream.
StreamNTyme
StreamNTyme is offline   Reply With Quote
Old 05-21-2012, 05:48 AM   #19
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by Silver Otter View Post
xo1...A few of us had an award company or t-shirt shop create a one-piece vinyl carrier with our numbers. I scanned the ones WBCCI sent, laid them up full size in Illustrator and then sent the PDF to the store. The number came back in consistent red, reversed on the carrier. I peeled the back coat and laid them on a light pencil line. Perfect!
If you do it that way, you can do the same with the Wally sticker, making one big adhesive panel with Wally sticker and all. I only see one problem; if you ever remove your numbers, you don't leave "ghost" numbers for the next owner to wonder about, as you would if each digit was applied individually.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 05-24-2012, 12:16 PM   #20
2010 25' FB Flying Cloud
Davenport , Iowa
I belong to both WBCCI and Air Forum and proud of both. Should go with the RED or BLUE? ( I have the same number for both.) Problem solved; I went with the good old RED, WHITE and BLUE in the flag motif. I had them done at the local sign shop. And yes, I put them on the Aluminum.
I'm also TAC, but put white numbers on the windows.
Airtandem is online now   Reply With Quote
